跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
How do I make this computer respond?
when booting this mac it only goes to the apple screen and had the loading ring..it will not go any further.. what should i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Reboot from the original system installation disk ( C key ). Go to the second screen pull down menu to Utilities > Disk Utilities and see if you can run the Disk Repair. Let us know your results please.
这个答案有帮助吗?
得分 3
3条评论:
So I've tried that and at one point it wouldnt eject the disk. It will not turn off using the power button. It just does what I stated before. Please tell me it's something I can fix myself with your help. Thanks!!
完成的
Did you get to disk utilities? Would it repair the drive?
完成的
No. It stays on the apple screen with a spinning loading cirlce it will not respond to the disk (c key). Honestly i think it would continue to stay on that screen til the battery dies. Is there anything else i can do?
完成的
添加一条评论
添加你的答案
kim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 232
