跳转到主内容
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Why won't my sterio work?but did before?
i put a cd player in my car before and switched it out for a newer cd player.now that i put a new one in it won't work.i double checked to make sure all wires where right and fuses...What else could it be for it not to work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Is it an aftermarket stereo or a Toyota brand? Do you use an amp with it? What was the issue with the old one? You just replaced it to go with a newer player?
完成的
i just replaced the stereo for a newer one. there is no amp connected.ok i will check the wires again..thank u both very much
完成的
添加一条评论
1个答案
已选择的解决方案
First thing I would do is test the power wire to the stereo with a volt meter and see if you are getting 12 volts from it and at the same time make sure the Ground source is also working, if that is good I would look for a fuse that is in the stereo itself and see if it's good, if that's all good then I would have to think the stereo may be bad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gamesnotwar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 501
