跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
I replaced iPod battery but why wont it stay powered up?
I ordered ipod replacement battery. I followed directions and installed battery into ipod. I noticed when I compared both batteries that the model numbers were different and the coupling cables were on opposite ends. I reversed new battery with label side down and reattached the cables. I snapped the case back together and attempted to charge ipod using the belkin ac adaptor 2.0 USB cable. Ipod powered up and the interneal circuitry on the hard drive was working. When I attempted to attach the USB to my computer to troubleshoot whether it would be recognized on the Apple itunes website it would not link it up. I disconnected from my computer and turned ipod on. It had about a 25% charge and actually booted up to the start menu. I went to music to see if it would play, it did this but then the ipod froze and the backlight stayed on. Does anyone know if this is a motherboard problem and I have "fried" the ipod? If so, I now have an expensive paperweight. Thanking you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Replace your battery again with the old one and see if that makes a difference. Have you had any other trouble with this iPod before you changed the battery?
完成的
添加一条评论
1个答案
Try a hard reset
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mdknght43 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 394
