跳转到主内容
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
17 个问题 查看全部
change cd drive to dvd -r/w, and airport card possible?
I have a Power Mac G4 Cube and I would like to put a DVD-R/RW drive to replace the CD drive. Is this possible? If so what model drive should I buy? Also,I'd like to put an airport wifi card in the machine as well... is the new Airport Xtreme compatible, or should I use the older Airport card?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi, you can put a DVD Drive in (not sure about disc burning though), as shown here:
But you can only have an Airport Card (not Extreme):
Hope that helps
这个答案有帮助吗?
得分 2
3条评论:
just out of curiousity- what app is that?
完成的
MacTracker
完成的
This is an old comment, I know by now, but thanks anyways.
完成的
添加一条评论
Actually you can as long as you remember these things the wireless is going to be limited to a or b connectivity only because it uses the older airport card as long as the drive is slot loading it really doesn't matter because you can remove the ice adapter off of the back of the current drive and attach it to any drive
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gaspar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 3,231
