跳转到主内容
问题已关闭
Single keys of my keyboard don´t work anymore?
Hi my iBook G4 has a little problem with some of the keys. The keys "sound off", "3", "e" and "d" do not work anymore. I connected an external keyboard and everything works great.
Any ideas what could be broken? Would it be enough to just change the whole keyboard?
Thanks, Anna
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If there are some keys that are not working then the solution is to replace the keyboard. Replacing the keyboard on that model iBook is fairly simple. Here is a link that I found from ifix:
[关联产品丢失或禁用: IF183-029]
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
Occasionally this can be corrected by re-seating the keyboard cable to the board, i.e. just pulling it out and connecting it again. Most likely you'll need a new keyboard, but this solves the problem often enough that it's worth trying.
Also, you can get them for about $12 on eBay.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,556
