跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
How can I completely remove the screen?
I want to remove the screen from my PowerBook G4 so I can use the base as a computer attached to my TV without any loss of functionality (I understand Airport and the Bluetooth antennas are connected to the screen?) All help appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I would follow the directions for removal of the LCD screen first as described here: PowerBook G4 Aluminum 17" 1-1.67 GHz Display Replacement
Then you should be able to remove the hinges.
这个答案有帮助吗?
得分 2
添加一条评论
You can separate your display assembly from your bottom case using the link mayer posted in his answer then open the display and remove the airport/bluethoot antenna cable. Simply reconnect the cable to your logic board and you will restore the wireless functionality.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dave Robertson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,305
