跳转到主内容
加入维修社区 - 创建账户
型号 M5343 / 333 或 400 MHz G3 处理器
What buttons to get to boot config screen?
Hello. I hope someone can tell me the keys used to reach th boot configuration setting at startup? Thank you for your time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I'm not entirely clear on what you mean by boot config. What is it you want to do? Ralph
由完成的 分享
Are you booting to System 9? Boot configuration setting is not mac language so most of us don't know what you're talking about.
由完成的 分享
Holding option and getting the Boot Manager is not always true on the early PowerBook G3s. Every time I hold Option this restarts it. On the Pismo, etc. it works as expected.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
If you hold down the "alt" key (may also be called "option") immediately after you hear the startup tone this will allow you to choose your startup disk. Bootable CD's will also show as available startup options.
If you know you want to boot directly from a CD then hold the "C" key down immediately after you hear the startup tone.
If you want to boot in target disc mode then hold the "T" key down immediately after you hear the startup tone.
**Remember this is assuming the commands are the same when working with G3's. (I have used them working with G4's & G5's)
Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
thank you for the reply. You have answered my question. I'm up and running smooth once again.
由完成的 分享
添加一条评论
添加你的答案
udreamibuild 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 31
总计 3,709
