跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Light and Proximity Sensor not working
I have had some water damage done to my phone and used my screen (front panel) with a friend's back panel, or body, who shattered his screen. Everything is working great, but the light and proximity sensor is not working at all and I keep hitting mute with my face. I have put the #3 cable back in sever times making sure flip the clip up and down and seem to have it all of the way inserted. It seems that the only way to get the metal case over cable 3, the proximity sensor off is to remove the glass, which id like to not do. Is there anyway to do this without taking off the glass? Thanks
Update
I did have to remove the LCD screen but not the glass front; I'm not sure which one is considered the digitizer. You can gently pry the sensor housing away from the frame and replace the sensor strip.
Check out this video on YouTube:
http://www.youtube.com/watch?v=m-wjCFGW4...
Update
I was able to replace just the proximity sensor in about 30 minutes, without special tools, and for under $10. I don't feel like the whole front assembly would be much easier and costs about 10 times as much. If you don't get the proximity sensor working for some reason, then you could go ahead and get the whole front assembly, but I did not because I thought $100, was too much to spend for a small repair.
Shopping results:
http://www.google.com/products?q=iPhone+...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi tyler, did the proximity repair require you to remove the digitiser from the frame? or can you remove the proximity sensor leaving digitiser intact?
完成的
添加一条评论
4个答案
已选择的解决方案
The glass can be purchased individually, but I'd suggest the frame+glass part to make things easy to deal with. It's slightly more expensive but worth it compared to bare glass.
If you need a guide to install it, this can be found here.
这个答案有帮助吗?
得分 2
3条评论:
I would like to know how to replace the speaker assembly, on a broken iPhone screen I could take off the glass and the lcd and get it down to the bare bones and take off the case for the sensor and the small sensor strip. Is this basically the same as replacing the speak assembly? Im sorry, Im just not very clear with what that is... Thanks for the help thus far.
完成的
Look on the internet for a guide
完成的
So I just swapped proximity sensor cables, the number 3 cable, from another iPhone and it is all working fine and dandy. Took a little prying to get the proximity sensor housing off without bending it and just put the other in its place. All is in great working condition now.
完成的
添加一条评论
All you have to do is pull the metal bracket off from the rear of the phone. It is the black metal bracket. I use a pick type tool to get it off without a problem.
这个答案有帮助吗?
得分 1
添加一条评论
You need to replace the iPhone's front panel assembly to correct this problem. This will fix the broken proximity sensor and the light sensor. It is easier than replacing just the sensors.
Replace a cracked glass screen on your iPhone 3G and fix a digitizer that no longer responds to touch. This part includes the front panel, ear piece speaker and home button.图片
产品
iPhone 3G Front Panel Assembly
$29.99
这个答案有帮助吗?
得分 0
添加一条评论
I did a write up to replace the ribbon, for anyone in the future that wants to attempt:
iPhone 3GS Proximity Sensor Ribbon Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 42,674
