跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
DC-in board from G4 to replace a broken G3 DC-in board.
Hello!
A broken DC-in board from an ibook G3 12" 800Mhz needs replacement.
I have a spare DC-in board from an ibook G4 14".
The logic board connectors are not compatible.
Can I strip the wires to transplant the G3 board connector to the G4 Dc-in board and use it as a replacement?
I know that I still have to figure how to secure the G4 Dc-in board inside the G3 since the screws are not located in the same configuration and the "tip module" is inverted. I'm pretty sure I can figure out that one, my concern is with the voltage output to the CPU.
Will the G4 14" Dc-in board output fry the G3 12"?
Thanks!
PS: Soldering is not an option for me, yet...will learn how to soon!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Sooo...nada so far.
It's okay, I'll "MacGyver" this one and post the outcome here.
The plan is to transplant as suggested in the original post above.
Stay tuned!
TBC...
完成的
添加一条评论
1个答案
已选择的解决方案
Are you really going to risk destroying your machine by MacGyvering a $1.00 part? http://www.gainsaver.com/Catalog/Detail....
这个答案有帮助吗?
得分 3
2条评论:
Hi mayer. It was one of those things that I wanted to do because it is unknown if it could work...I wanted to boldly go where no one has gone befo...anyway, DO NOT DO IT! The cables are way too thin to strip and reconnect.
BTW thanks for the gainsaver.com link, I might get it if the logic board connector is included.
Cheers!
完成的
UPDATE Hi mayer, I contacted gainsaver.com and much to my surprise, and disappointment, they sell the dc in board without the logic board connector ribbon, thus the $1 price. Regardless, thank you for the tip. Cheers!
完成的
添加一条评论
添加你的答案
Ephraim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 693
