跳转到主内容
苹果的外置光驱,本质上是MacBook Air SuperDrive的重塑。
35 个问题 查看全部
Use the internal SuperDrive in a MacBook Pro?
The internal MacBook Pro's SuperDrive cost 100$ and the USB SuperDrive only cost 80$.
It is possible to get the internal drive of Macbook Air SuperDrive to put in a MacBook Pro Unibody ?
EDIT : I dont use Google sorry
While the MacBook Air SuperDrive only works externally with the MacBook Air possibly due to the USB adapter (Update: confirmed), the internal drive component is interchangeable with the internal 12.7mm 17″ Macbook Pro and most G4 PowerBook drives. It will not work with 15″ MacBook Pro or 13.3″ MacBook models since they need a slimmer 9.5mm SuperDrive.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
My older MacBook Air Superdrive (2008) uses a:
Sony DVD/CD Rewritable Drive
Model No AD-5630A
这个答案有帮助吗?
得分 3
添加一条评论
Of course,
Many vendors offer an superdrive external enclosure when you buy a second drive or an SSD ( this works all Apple optical slot in ). At this time is cheap near $ 25, but if you buy it as "standalone" expect $ 40.
At work I toke all drives inside iMacs and placed them on external enclosures, but many went to stockroom ( pocketed with drying product ).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yoann Frommelt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,197
