跳转到主内容
加入维修社区 - 创建账户
It won't shut down!
This is a weird one, when I tell it to shut down, it restarts. Anyone know why?!?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Apple menu...shut down...it restarts...it's supposed to shut down not restart. The only way I can get it to turn off is if I hold down the power button. Is this just the way the laptop works? If so I feel stupid...
完成的
What happens when you hold it down? Keep it held down for a while. You may have to do a power manger reset.
完成的
Like I said, if I hold down the power button it works, it shuts down. It doesn't however shut down when I tell it to from the apple menu. All updates are current.
完成的
Try resetting the smc.
完成的
The only thing I haven't tried out of all these suggestions is re-loading OS software, but nothing has worked so far. Another thing I noticed when I plugged in it's charger, it turns on...
完成的
添加一条评论
3个答案
已选择的解决方案
See if it happens in Safe Mode:
To start up into Safe Mode (to Safe Boot), do this:
Be sure the computer is shut down.
Press the power button.
Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
这个答案有帮助吗?
得分 3
2条评论:
Here's Apple's discussion of the problem, you might want to subscribe to this: http://discussions.apple.com/thread.jspa...
完成的
Like I said above, I tried everything listed in that post accept the re-loading the OS...
完成的
添加一条评论
How exactly do you tell it to shut down? To make sure it shuts down hold the power button until it turns on. It should not turn back on.
这个答案有帮助吗?
得分 1
添加一条评论
Try clicking on apple, software update.....the problem may be due to software, and hopefully not hardware.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 5,479
