跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Water-damaged iPhone 4 - Dock vs. Battery
I have a water-damaged iPhone4. I disassembled it and the logic board appears fine. When plugged into the wall, it boots to the password screen and asks for Activation. If unplugged, it immediately turns off. It doesn't connect to the computer
Questions:
1. Is it likely that it is the battery or the dock connector?
2. Why am I being asked to Activate again? Is my data gone?
3. If I need a new dock connector and/or battery, what are some trustworthy vendors?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
even so the logic board looks fine, I would definitely still clean it. After that, do replace the battery. One should never re-use a battery that may have had any water damage
完成的
添加一条评论
1个答案
Battery issue. It is asking to activate again because the logic board is not getting enough power to "pull up" your information. Most likely after placing a new battery in the device it will work properly and all of your data will still be there. I would just buy a battery from this site.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Seth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 455
