Can I insert DDR3 1333MHz RAM into my MacBook?
I have MacBook (Generation 6) with 2Gb RAM installed. I have a possibility to get 2x 2Gb DDR3 1333MHz RAM's. Can I insert this RAM into my Mac?
The MB467 comes with 2 memory slots carring 1 GB 1066Mhz DDR 3 Ram module in each one (PC3-8500 DDR3).
From everymac.com
"Apple officially supports a maximum of 4 GB of RAM. Originally, this model was only unofficially capable of stably supporting 6 GB of RAM, but as confirmed by site sponsor OWC, it is capable of supporting 8 GB of RAM if updated to Boot ROM Version MB51.007D.B03 and running MacOS X 10.6 "Snow Leopard" or higher."
这个答案有帮助吗?
Interesting that the stock RAM is 1066 MHz. Faster RAM will work, but it will most likely run at 1066 MHz.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,155
2条评论
An important number from the RAM that might help with determining this is the pin count. Please add this. Also, check with the ID Your Mac page and go to the store page at the end. If iFixit sells the part for your machine, then it'll work!
由 Adam Hintz 完成的
Apple MacBook "Core 2 Duo" 2.4 13" (Unibody) Specs
Identifiers: Late 2008 Aluminum - MB467LL/A - MacBook5,1 - A1278 - 2254
由 mayer 完成的
