跳转到主内容
The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
28 个问题 查看全部
How Can I fix the accelerometer?
My accelerometer does not work anymore. I donwloaded some apps and just show "0". Soo, how can I fix it if is possible.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Have you tried to reset/restore your phone?
完成的
添加一条评论
1个答案
已选择的解决方案
The accelerometer is a chip soldered to the main board in all phones.
The only easy way to fix it is to replace the main board but it can be expensive.
But if you have the part its possible to do.
这个答案有帮助吗?
得分 1
1条评论:
The Nexus S uses the InvenSense MPU-6050 three-axis gyroscope and a three-axis accelerometer. It is available at places like this. you can get the datasheet from here. The datasheet will also explain the mounting of the IC as well as reflow parameters.
完成的
添加一条评论
添加你的答案
Samuel Cortez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,643
