跳转到主内容
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 个问题 查看全部
Can I use a 800 mhz DVI logic board
I have a PowerBook G4 667 mhz DVI 15 inch with a bad logic board. Can I replace it with a 800 mhz DVI 15 inch logic board? are they interchangeable? Also, what about switching display assemblies from one to the other?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes, you can put a 800 MHz DVI board in a 667 MHz machine, but it is recommended to also install a secondary fan as well (the 667 MHz machines do not have the secondary fan). As for the displays, DVI displays are also interchangeable. You cannot, however use earlier Titanium model displays (Mercury or Onyx machines).
Good luck!
这个答案有帮助吗?
得分 1
3条评论:
I knew you would know. Can he also go to the 1000 MHz board? +vote
完成的
yes! but he would need a different secondary fan.
完成的
Where does a Powerbook G4 Titanium DVI 867 secondary fan plug in?
Please reply to RHBernard@gmail.com of 203-984-2070
完成的
添加一条评论
You may be in luck. There are four logic boards listed for the G4 Titanium. A 667, 800, 867 and a 1000. Ben Eiseman is the parts man around here. He should be able to tell you in the morning which ones will work. Here's the boards: http://www.ifixit.com/Mac-Parts/PowerBoo...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
robert owen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 816
