跳转到主内容
How should I repair a dinged up LCD screen case?
Macbook Pro 13" LCD screen case Nov 24 @ 4:26 PM
Hey,
The aluminum case of my screen has serious scratches and some dings...had an accident yesterday!!
I am really annoyed by that!!
I have seen they offer upper and lower cases for the macbook, but I couldn't find any case for the screen!
Does anyone have any ideas where to get a new screen casing, or maybe something to get rid of the scratches?
Thanks a lot,
Max
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
The Macbook Pro 13" LCD display is hard to dismantle. With the iBooks and PowerBooks and even plastic macbooks models it was easy to swap the panel case, only 2 or 4 screws to unscrew and the job was done but with the unibody MBP 13"/15"/17" Apple made it more difficult. You need to heat the glued front glass to take it out and have access to the screws that retain the LCD screen. Doing this would probably void the warranty if you still have one and you could also damage the LCD if too much heat is applied to the screen. A complete LCD display swap would be more secure but would also cost much more.
这个答案有帮助吗?
得分 2
添加一条评论
Display case or back is what you're looking for. There are some here on occasion, also on eBay, you might be able to pick up a pretty good case from a water damaged Macbook.
Good Luck,
N.
这个答案有帮助吗?
得分 1
添加一条评论
sandpaper to get sharp edges off, get a uniform look,
paint it and have a custom MacBook ;)
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for the answers! I couldn't reply before cause my school blocked this site!!
I think I will keep looking on ebay for an occasion to buy a complete LCD display!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maxeyy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 3,024
