简介
Upgrade your hard drive for more storage space.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
在这个步骤中使用的工具:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Lift the the retaining bracket out of the upper case.
208等其他人完成本指南。
13条评论
Piece of cake! Didn't have the 5-point, so I left the battery alone. Finder says I have 550G of free space!
bgranquist - 回复
Very Easy. Don't need to remove the battery.
Hi. Does myy macBook Pro (15" Mid 2009) support Solid State Drive? I upgraded the memory with 8 gigabites, but it´s still a bit slow. I hope someone can answer soon.
Yes you can. Look up crucial.com
kris -
