跳转到主内容
1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement
你所需要的
  1. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: 步骤 1 中的图像 1,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: 步骤 1 中的图像 2,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement, Power Steering Pressure Hose: 步骤 1 中的图像 3,3
    • Here is a view of the power steering pump. It is located on the front left side in the engine compartment. Visible fresh oil stains on the fan shroud and other parts.
    • Most sludge was found at the pressure line connection
    • The leak is on top of the flare nut where the pipe enters the pump.
  2. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 2 中的图像 1,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 2 中的图像 2,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 2 中的图像 3,3
    • To remove the hoses from the power steering pump, the air cleaner housing has to be removed. Remove the four clips on the air filter cover
    • Remove the air filter
    • Loosen the clamps from the air intake duct to remove the air cleaner cover from the engine.
  3. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 3 中的图像 1,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 3 中的图像 2,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 3 中的图像 3,3
    • Here is the complete housing. There are three 13mm hex head mounting bolts for the air cleaner housing. One on the front left
    • one on the rear left
    • and the last one is difficult to find on the front right.
  4. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 4 中的图像 1,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 4 中的图像 2,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 4 中的图像 3,3
    • All three bolts have lock nuts that can be accessed from the driver side front wheel well
    • Use a socket wrench or similar tool to loosen the bolts, then remove the nuts in the wheel well.
    • All three bolts and nuts are identical
  5. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 5 中的图像 1,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 5 中的图像 2,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 5 中的图像 3,3
    • With the three bolts remove the air filter housing can simply removed. This gives full access to the power steering gear and hoses.
    • New line.
    • Use a 16mm x 18mm flare nut wrench. It will be safer than an open end wrench since it provides a better grip. This will prevent any damage to the flare nut on the hose.
    • Disconnect the hose on the power steering pump by loosing the flare nut in a counter clockwise rotation
  6. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 6 中的图像 1,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 6 中的图像 2,3 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 6 中的图像 3,3
    • Disconnect the hose on the power steering gear by loosing the flare nut in a counter clockwise rotation
    • Once both ends are disconnected, remove the hose from the vehicle.
    • New line.
    • Install the supplied O-rings on either side of the new hose.
  7. 1999-2004 Jeep Grand Cherokee Power Steering Pressure Hose Replacement: 步骤 7 中的图像 1,1
    • Install new power steering pressure hose.
结论
16等其他人完成本指南。
oldturkey03
于09/29/10注册
784,315 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了560篇指南
9条评论
This was so helpful! I have this exact issue with my power steering and this guide is going to make the job very easy! Thanks for posting this it really helped a lot!
Hadley Hofreiter - 回复
Doing this job today thanks for making this! I didn't know I would need a flare nut wrench and luckily found one pretty cheap
Albert Einstein - 回复
After topping up the steering fluid, the system can be bled again by turning the wheels from left lock to right lock a few times. Much easier when both wheels are off the ground.
Andries Holtzhausen - 回复
Does the fluid not need to be drained out before removing the line?
Dave - 回复
@dave7777 nope. Place a rag under the hose before you take it off so it does not leave to much of a mess. Check the fluid after.
oldturkey03 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 38
过去 30 天: 194
总计 42,913
