学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Battery will not charge
Phone will not charge when plugged into charger.
Defective charger
If the phone and charger are plugged in, and there is not indication of charging, the charger may be faulty. This is an easy fix. Simply purchase a new charger designed for the phone. A universal charger works with this phone.
Defective battery
Cell phone batteries have a life span just like any other battery. To replace your battery you can this guide here.
Loose charging port
The connections in the charging port can wear out over time. The port may also become warped to the point the charger does not fit securely. Please follow the guide here for information on replacing the port.
Phone will not turn on
When power or home button is pushed, the phone fails to turn on and display the home screen (or lock screen depending on your settings).
Dead battery
Although this may seem obvious, it is best to ensure the phone has a charged battery. Simply plug in the charger and the screen will turn on to let you know it’s charging. If this doesn’t happen, see the “battery will not charge” section of this guide.
Buttons don’t respond immediately
Hold the power button down until the menu screen displays, then tap “restart”. Alternatively, select “shut down” and leave device alone for two minutes before turning it back on.
How to reset lock screen pass code or pattern
How to regain access to your phone when the lock pattern or code has been forgotten. You will need login information for your google account. This section assumes a basic understanding of electronics troubleshooting. For more detail information (suggested for novices) visit this WikiHow.
Resetting pass code or pattern
Accessing your locked phone without the lock code or pattern (hence forth called ‘lock sequence’) can be time consuming, but is simple enough. Input your lock sequence five times. This will allow a bypass option to appear. Select ‘forgot pattern’ or ‘forgot password’ at the bottom of the screen. Enter your google account information associated with the phone. Go through the on screen steps to reset your lock sequence.
Performing a factory reset
Resetting your phone to factory default will delete all data on the phone. Once completed, the process cannot be undone. Power off the phone by holding the power button and selecting “power off” when the option appears. Press and hold the ‘volume down’ button then press and hold the power button at the same time. Hold these two buttons for about 30 seconds or until the android symbol appears. Use the volume buttons to navigate to “factory reset”. Use the power button to select the highlighted option. Resetting the phone will take several minutes. Once it’s finished, you will have to set it up as if you just got it out the box for the first time.
Music won’t play/speakers won’t work
Videos or music will say they are playing, but no sound is coming from the speakers or headphones.
Checking volume level
Make sure the volume is turned to an audible level by using the buttons on the side of the phone. Another way to adjust the volume is by going into the drop down menu by sliding down on the phone screen and turning the volume up manually with the sliding bar.
Performing a soft reset
Try cycling power by performing a soft reset. Complete this by pressing and holding the volume up and power buttons simultaneously on the sides of the phone for 10 seconds. This should turn the phone off then back on again.
Checking the format of audio file
If the audio is still not playing try looking up the properties of the audio file you are trying to listen to. If the file is not compatible with the phone the file will not be able to play.
Replacing the loud speaker
If none of the above options seem to be the problem and the loud speakers still aren’t making sound, it might be a problem with the actual loud speaker itself. Follow this guide to replace the loud speaker on your HTC Desire 626s smart phone.
Replacing the aux port (headphone jack)
If the loud speakers are working properly, but no sound seems to be coming from the connected headphones, there might be a problem with the auxiliary port (headphone jack) in the phone. Follow this guide to learn how to replace the aux port on your HTC Desire 626s smart phone.
Pictures come out fuzzy and not clear
Camera won’t seem to focus on something to take a clear picture. Pictures that are taken might appear blurred or discolored.
Lens debris
Check for dirt or moisture that might be on or around the camera lens that could be obstructing the view. If there is, remove it with a cloth or paper towel, you can lightly wet the towel if necessary.
Low photo resolution
Make sure the photo resolution setting isn’t turned down. You can view and change this setting by going to the camera application, then settings, and finally resolution.
Adjusting the focus
If it seems the camera is simply not focusing on an object or person you want to take a picture of you can fix this in the focus settings of the camera application. First, go into the camera application, then Focus Mode. Then, check the Auto Focus mode, if the macro mode was previously on before switched to auto. This should fix the issue.
Changing the photo application
Sometimes the HTC Desire 626s camera application just produces blurry pictures and we can’t explain why. However, a solution to this problem is to go to the PlayStore and download another camera app. This should link to your camera and hopefully give you a clearer picture.
Bad camera
If none of these previous options work, it could be that you have a faulty camera in your HTC Desire 626s phone. If this is the case follow this link here to see how you could replace your camera.
0条评论
