跳转到主内容
HTC Desire 626s Loud Speaker Replacement
你所需要的
  1. HTC Desire 626s Loud Speaker Replacement, Backplate: 步骤 1 中的图像 1,3 HTC Desire 626s Loud Speaker Replacement, Backplate: 步骤 1 中的图像 2,3 HTC Desire 626s Loud Speaker Replacement, Backplate: 步骤 1 中的图像 3,3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Loud Speaker Replacement: 步骤 2 中的图像 1,2 HTC Desire 626s Loud Speaker Replacement: 步骤 2 中的图像 2,2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Loud Speaker Replacement: 步骤 3 中的图像 1,2 HTC Desire 626s Loud Speaker Replacement: 步骤 3 中的图像 2,2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
  4. HTC Desire 626s Loud Speaker Replacement, Loud Speaker: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift the speaker straight up.
    • You can locate the loudspeaker at the base of the phone; it should have a white sticker on it.
  5. HTC Desire 626s Loud Speaker Replacement: 步骤 5 中的图像 1,2 HTC Desire 626s Loud Speaker Replacement: 步骤 5 中的图像 2,2
    • Wiggle the loudspeaker with the tweezers if it does not at first come out.
    • Congratulations you have successfully removed the loudspeaker.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 231
