学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Screen is unresponsive
Touch screen does not work.
System is Frozen
First, the system should be rebooted to see if the problem still persists. Press the power button to restart the computer and progress from there.
Screen is Cracked
Visibly confirm that your screen has one or multiple cracks in it. If you've noticed cracks and have a spare screen for this device, begin replacing the screen using this replacement guide.
Laptop won't turn on
Power button pressed but laptop will not start.
Faulty Charging Cord
Check that the battery is charged and/or the charging cord is plugged in. Try a different charging cord if possible.
Broken Power Button
Ensure that the power button functions properly and isn't jammed or broken.
Bad Battery
If all else fails, the battery could’ve gone bad and needs to be replaced. To replace an old battery use this replacement guide.
Out of Memory
The laptop is unable to save any more files, or is slow to pull up files
Solid State Drive (SSD) Full
Navigate to the file explorer and check your current hard drive storage in the “my computer tab.” If the storage is full, you can either gain space by deleting files, transfer files to an external storage source, or upgrade the internal solid state hard drive using this replacement guide.
Bad or No Audio
Speakers on the device are either not playing sound or playing corrupted sound
Corrupted Sound File
Ensure that the volume on the device is not muted or that the media is indeed playing the correct sound. A good way to test whether the audio issue is from the media file or from the computer is by alternating the sound output from the speakers to headphones. To do this, plug a pair of headphones into the headphone jack, play the audio file, and listen to the output from the headphones. If sound comes out of the headphones, the problem is with the device's speakers. You can replace them using this replacement guide.
Broken Speakers
The speakers on the device may be broken and replacement is required. To replace the speakers follow this replacement guide.
Unresponsive Camera
The back camera does not function properly
Camera damaged
Try restarting the device and if the camera is still unresponsive or isn't functioning properly then it might be time to replace it. Begin replacing the back camera using this replacement guide.
一条评论
Laptop is not turning on and it get heated
sometimes
I domt what to.do.
There is a single flash in capslock
Anupriya Gupta - 回复
