学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Battery That Will Not Stay In Place
When I try to put my battery in place, my battery keeps falling out.
Faulty Clip
Make sure before you put your battery in that your clip is up. To see if your clip is up, test the clip by pushing down on it. You want your clip to pop back up. Then your battery is ready to be put it.
Incorrectly Positioned Battery
Make sure you have the right side facing the inward. Put the larger end of the battery at the top of the insert which is right below the speaker. Then push your battery all the way in. You should hear your battery click into place.
GPS is Not Turning On
When I try to use my GPS, it will not turn on.
Uncharged GPS
Battery life is limited so it won't last forever. Make sure before using the GPS that you have fully charged it. Then you will be able to properly use your GPS for your trip.
Charger is Faulty
Another simple solution is to check your charger is working properly. Find another device that can use your GPS charger and try to charge it. If it is not charging that other device then your charger could be faulty. An easy solution is buying a new charger so you can use your GPS again.
Battery is Faulty
If you have tried the two previous steps and your GPS is still not turning on, then it could be a faulty battery in your GPS. You can easily replace your battery.
Motherboard is Faulty
The GPS does not have many components to it. If you have tried both of the previous steps and had no success then your motherboard could be faulty. You can easily replace it yourself.
Unable to Hear the Device's Directions
When I am using my GPS, I can’t hear it.
Low or Mute Volume
Go to your GPS’ settings and make sure the volume is on. Then adjust the volume to one that is more audible. This should help you with your volume issues.
Bad GPS Placement
When putting your GPS in your car make sure that is it in a spot that isn’t surrounded by other objects. You don’t want other objects to be in the way of the speaker by either muffling it or blocking it out completely.If you are still have issues and are unable to hear the GPS, you may need to replace your speaker.
The Touchscreen is Not Responding
When I am using my GPS, the touchscreen is not responding at all.
Too Many Commands
Your GPS is a great piece of technology but it can't do a million things at once. If your GPS is not responding, give it a minute. It might need a minute to think and process your commands. Once is does your command then continue with the actions you wanted it to perform.
GPS Needs a Restart
When your GPS is not responding, turn it off for about 2 minutes. Then power it back on and it should start responding.
LCD Screen is Faulty
Your LCD screen is pretty durable but sometimes they do become faulty especially the longer you have your GPS. If your GPS does not respond to your touch anymore then you need to replace your screen.
GPS is Not Charging in the Car
When I have my GPS plugged into my car to charge, it won’t charge.
Loose or Unattached Cables
When using a charger make sure all the parts are plugged in. So make sure that the charging end is firmly placed in the car charging port. Then make sure the cable is firmly plugged into the GPS.
Car Charging Cable is Faulty
If your GPS is not charging, your car charging cable may be no longer working. Inspect your cable to make sure there are no rips or tears. Rips and tears may lead to a defective cable. In either case, you will need to purchase a new car charging cable.
Car Outlet is Faulty
If the two previous steps have not fixed your GPS charging problem then it could be your car outlet itself. Try charging you GPS in another car to see. If your GPS charges in other cars then you will need to have your car outlet inspected because it may be faulty.
4条评论
unable to cancel speaker muted on the screen for a nuvi2797
Nat Srinivasan - 回复
how long does a charged up nuvi 2797 last while in operation.
laytmp - 回复
My Garmin is no longer tracking my car or giving me commons to where I have to go but I can see the line and the checker flag but it isn't telling me where to go I've bin goggling it with no answer help!
Chanin Robilotti - 回复
Garmin Nuvi 2797 LMT - Unable to enter destination address under “Where to? “ Command” NAy ideas on how to fix?
Kathy Taylor - 回复
