跳转到主内容
Garmin Nuvi 2797LMT LCD Screen Replacement
你所需要的
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 2797LMT LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
结论
4等其他人完成本指南。
baileykaytar
于10/13/15注册
366 声望
创作了2篇指南
团队
2条评论
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - 回复
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 2,339
