学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Drill Does Not Hold Charge
No matter how long I charge it, the drill doesn't stay working
Bad Battery
If your drill operates while connected to charger, but does not operate while disconnected, you may have a defective battery. If this is the case, you may need to purchase a new battery and install it using our battery replacement guide.
The AC Cord is Defective
At this point you have determined that the battery is indeed not defective. Now, check and see drill operates while connected to charger. If the drill still does not turn on while connected to a power outlet then check and see if the AC cord has any kinks or exposed wire. If this is the case, you will need to buy a new AC cord.
Not Enough Drill Power
The drill gets to a certain point and bogs down
Motor Issues
Disassemble the drill and locate the motor. While drill is disassembled, squeeze the trigger and see if the motor is rotating properly. If motor is not functioning correctly, visit our motor replacement page to learn how to properly replace your drill's motor.
Trouble Adjusting Drill Speed
The drill switch is not adjustable
Adjusting the Speed Switch
Make sure that the speed switch on your drill is positioned in the proper position. Locate the gear indicator on the top of the drill. Make sure the switch is set on the high-torque setting. This setting allows the drill to deliver 130-inch-pounds of power. If your project requires more torque, you may want to consider getting a more powerful drill. Visit our speed switch replacement page to learn how to properly replace the switch.
Drill Does Not Grip Bits Well Enough
The bit will not stay steady while in operation
Chuck Needs to be Replaced
If chuck is properly fastened, and continues to lose grip, then it is possible that you may need to entirely replace the chuck.
Motor Has Gone Bad
The drill has power, but it won't turn
Motor Needs to be Replaced
Once you have determined that the motor is the problem (refer back to "Not Enough Drill Power" section, under Motor Issues), you may need to purchase a new motor for you Black and Decker SS12C. After purchasing a new motor, refer to our Motor Replacement Guide for further instructions.
3条评论
What is the problem of my drill? motor is fine and rotating and hold the screw bits by the chuck but it slipped when you doing the actual screwing.
Please help! just bought it a month ago.
roderickcayabyab - 回复
I can't get the battery off to replace it.
levvie hammon - 回复
how do you remove the battery it is like glued on or frozen and does not move
levvie hammon - 回复
