跳转到主内容
Black and Decker SS12C Battery Replacement
你所需要的
  1. Black and Decker SS12C Battery Replacement, Battery: 步骤 1 中的图像 1,3 Black and Decker SS12C Battery Replacement, Battery: 步骤 1 中的图像 2,3 Black and Decker SS12C Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: 步骤 2 中的图像 1,1
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: 步骤 3 中的图像 1,3 Black and Decker SS12C Battery Replacement: 步骤 3 中的图像 2,3 Black and Decker SS12C Battery Replacement: 步骤 3 中的图像 3,3
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: 步骤 4 中的图像 1,2 Black and Decker SS12C Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: 步骤 5 中的图像 1,3 Black and Decker SS12C Battery Replacement: 步骤 5 中的图像 2,3 Black and Decker SS12C Battery Replacement: 步骤 5 中的图像 3,3
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
结论
2等其他人完成本指南。
一条评论
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 840
