跳转到主内容
加入维修社区 - 创建账户
The pictures I took don't clearly explain all the processes I apologize, but hopefully the captions will help you. Also I'm new to this, so sorry for bad pictures.
你所需要的
工具
本篇指南是分解流程而非维修指南。 如果您要维修您的Xbox,应参考我们的维修指南。
    1. Xbox Teardown, Taking of the Top: 步骤 1 中的图像 1,1
      • Flip over the Xbox to where it shows the bar codes. Take of the black grips. Also scratch around where it has the stickers to find the screws there are a total of six, 2 of the screws are within the stickers.
      询问修复机器人
      添加评论
    2. Xbox Teardown, The Top: 步骤 2 中的图像 1,1
      • (This photo is not mine it was from another ifixit and i will use 5 photos from them since i couldn't find the ones i took)
      • When you get the screws off use the spudger to get it open by finding a crack that goes all around the xbox
      询问修复机器人
      添加评论
    3. Xbox Teardown, Removing the Hard Drive pt1: 步骤 3 中的图像 1,1
      • After you take of the top you will see all the circuits.
      • Look around and you will find 3 screws that are holding down the disc drive and remove them.
      询问修复机器人
      添加评论
    4. Xbox Teardown, Removing the Hard Drive pt2: 步骤 4 中的图像 1,1
      • When you do that just take off the disc drive depending on what you are trying to fix just unplug the wires going to it and set it aside.
      询问修复机器人
      添加评论
    5. Xbox Teardown, Removing the Disc Drive: 步骤 5 中的图像 1,1
      • Unplug any wires that seem to be poking out then take out the disc drive which should just come out.
      • Same thing if its not your focus just put it to the side.
      询问修复机器人
      添加评论
    6. Xbox Teardown, The Ribbon: 步骤 6 中的图像 1,1
      • The rest are my pictures
      • Remove the ribbon carefully
      询问修复机器人
      添加评论
    7. Xbox Teardown, The Rainbow Wire: 步骤 7 中的图像 1,1
      • Somewhere on the motherboard there will be a multi-colored wires that are together and just simply unplug it.
      询问修复机器人
      添加评论
    8. Xbox Teardown, Removing the Transformers: 步骤 8 中的图像 1,1
      • To the left of the Rainbow wire there are a lot of transformers which we will need to take out.
      • There will be screws holding it down so just look around the transformers.
      • Disconnect any wires that are connected to it before picking it up.
      • Set it aside if its not what you are going for.
      询问修复机器人
      添加评论
    9. Xbox Teardown, The Motherboard: 步骤 9 中的图像 1,1
      • When the transformers are gone look around the motherboard which should be the last electronic left.
      • There also will be screws around,when you find them unscrew them and all you have to do know is carefully take out the motherboard
      • Then your done at taking out the motherboard.
      询问修复机器人
      添加评论
Justin Moreno
于11/08/16注册
219 声望
撰写一个指南
1指南评论
you forgot to mention the fan shroud, which, if i remember correctly is a bit tricky to remove
pantsaremyfriend - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 125
总计 9,138
