跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Xbox 360 S,请使用我们的维修手册
  1. Xbox 360 S Teardown, Xbox 360 S Teardown: 步骤 1 中的图像 1,1
    • Slide latch back and pull up to take the part of the side cover off.
  2. Xbox 360 S Teardown: 步骤 2 中的图像 1,1
    • Take a flat head screwdriver and pull up on the two ends of the side cover.
  3. Xbox 360 S Teardown: 步骤 3 中的图像 1,1
    • It would be a good idea to take out your hard drive so gently pull it out and set it aside.
  4. Xbox 360 S Teardown: 步骤 4 中的图像 1,1
    • Take your flat head screwdriver and lift up on every hole like the ones circled in the picture until it comes off.
  5. Xbox 360 S Teardown: 步骤 5 中的图像 1,1
    • To take off the frame, take a flat head screwdriver and pull of the latches until it comes off.
  6. Xbox 360 S Teardown: 步骤 6 中的图像 1,1
    • Take your flat head screwdriver and place in one of the cracks of the side cover on the other side and pull up to take it off.
  7. Xbox 360 S Teardown: 步骤 7 中的图像 1,1
    • Take your flat head screwdriver and place it in the holes like the ones in the picture until the piece comes off.
  8. Xbox 360 S Teardown: 步骤 8 中的图像 1,1
    • Take a T10 Torx screwdriver and unscrew your network chip so you don't ruin it.
  9. Xbox 360 S Teardown: 步骤 9 中的图像 1,1
    • Take your flat head screwdriver and unlatch the two latches and then place a different screwdriver through the latch so it doesn't latch.
  10. Xbox 360 S Teardown: 步骤 10 中的图像 1,1
    • On the other side, take your flat head screwdriver and unlatch the latch. There is a harder latch farther inside so you have to stick the screwdriver far down and try to find it by feeling around. It helps to push both sides of your Xbox security sticker.
  11. Xbox 360 S Teardown: 步骤 11 中的图像 1,2 Xbox 360 S Teardown: 步骤 11 中的图像 2,2
    • Use your T8 and T10 Torque screwdriver and take out the five black screws that are shown in the picture.
  12. Xbox 360 S Teardown: 步骤 12 中的图像 1,3 Xbox 360 S Teardown: 步骤 12 中的图像 2,3 Xbox 360 S Teardown: 步骤 12 中的图像 3,3
    • Take your front cover with your home and eject button and lay it down in front of the console. The front cover is connected to a power source by the home button. Be very careful to pull it over and then out so you don't break it.
  13. Xbox 360 S Teardown: 步骤 13 中的图像 1,1
    • This is what you will see when you are done with all the previous steps. For other teardowns like the disc tray or power source, look at ifixit.com to get the best on how to teardown something.
Julian Gonzalez
于04/19/18注册
383 声望
撰写一个指南
13条评论
Some of these photos are just zoomed in and I have no idea which side, or which way up they are in respect of the console. I recommend further photos for clarity.
I don’t have this console, but I just like going through the teardowns.
Keith Woolven - 回复
i have the console and it was pretty easy to follow, the only thing was the last clip he was saying to just feel around for, i just pushed in on the spot where it would be and it separated easily after that
MrrCabooodle -
This is pretty bad, pretty vague. I had to refer to a YouTube video for more information and a visual demonstration because this how-to is sparse in information. This article fails to mention what is happening at crucial steps and does not describe how it should feel when pieces come apart; if I only had this article to refer to, I probably would have given up in fear that I’d damage the case or system. I did eventually get my case apart, hardly any help from this source, sadly.
Anthony Albanese - 回复
Hi Anthony,
As stated in the warning at top, a teardown is an educational look at the device, and is not meant to be used as a guide. Our repair guides will show up here, and contain accurate details (such as tools needed, how to unlock ZIF connectors, etc.) as well as step by step instructions on how to complete the repair.
Arthur Shi -
In the middle of the sticker on the back there is a pin hole to put something into to get the last clip off
Luke Eastley - 回复
添加评论
浏览统计数据:
过去 24 小时: 55
过去 7 天: 426
过去 30 天: 1,806
总计 93,496
