简介
It's been nearly two years since Google unveiled its flop of a streaming media player, the Logitech Revue. After a lengthy hiatus from the spotlight, Google TV is back to take the stage. Its lead actor? The ironically-named Vizio Coaster Co-Star.
Want to keep up with all of our latest teardowns? Follow @ifixit on Twitter!
你所需要的
Providing the market with a $99 answer to the Apple TV (also $99), the Vizio Co-Star brings a refreshing reincarnation of Google TV to the world of set-top boxes.
Notable tech specs:
Google TV platform
Wi-Fi and Bluetooth enabled
Hot buttons for Amazon, Netflix, and M-Go
720p, 1080i, and 1080p resolution support
MP3, AAC, and WMA audio playback
Universal QWERTY remote with trackpad
The rear side of the Vizio Co-Star includes an impressive lineup:
USB 2.0 port
HDMI-In port
HDMI-Out port
Ethernet port
DC-In Power port
On the bottom we see the reset switch and four suspicious-looking rubber feet.
A little prying around the edge with a plastic opening tool, and we've got the bottom panel free.
Comparatively speaking, the Apple TV required two metal spudgers to open, as opposed to a single plastic opening tool here. No need to split hairs; they're both easy to open up, and we love it.
And here comes the Co-Star's motherboard strolling down the red carpet:
Marvell Armada 1500 1.2 GHz Dual-Core Processor
Marvell 88DE2755 QDEO Video Processor
Nanya NT5CB256M8GN-DI 2 Gb DDR3 SD RAM (2 Gb x 4 for 1 GB total RAM)
Samsung K9GBG08U0A-SCBO 32 Gb (4 GB) NAND Flash
We're used to the innards of devices being dominated by a single component, but those space hogs are usually batteries or power supplies.
Over a third of the real estate in the Co-Star is inhabited by the aluminum heat sink.
The answer lies in air movement. Without fans to circulate air, there is no forced convection. Therefore, the Co-Star must rely on conduction and natural convection to keep the processor cool.
We use our always-trusty spudger to disconnect the Bluetooth and Wi-Fi antenna cables from the wireless board.
A Marvell Avastar 88W8787 WLAN/Bluetooth/FM Single-Chip SoC brings life to what would otherwise be a very bland and boring board.
Just like the Boxee Box, the Co-Star comes with a neat two-sided remote.
Unlike the Boxee Box though, this Vizio controller is universal and features a touch-sensitive trackpad. Point, Co-Star.
As a finishing touch, the Co-Star remote has ABXY buttons and a directional pad for OnLive gaming. Not only is that an incredibly unique feature, it gets us all nostalgic and stuff.
Here's another opportunity for the modders out there. How cool would it be to have a neon green keyboard bezel to match your Co-Star?
Whether you're painting it or not, the bezel pries off the keyboard quite easily.
Following suit, the rubber button cover peels off without a problem.
Since the button cover and the bezel are the components that usually get the dirtiest, it's great they are easy to remove.
Buttons on both sides mean lots of data transfer. Luckily, the data cable slides out from connectors on both PCBs.
The Co-Star's remote looks to be as easy to take apart as the media player itself.
Once again, this isn't really a surprise. Remotes, unlike smartphones or laptops, aren't subject to strict space constraints.
Yoink!
We grab a handy pair of tweezers and gently pluck out the trackpad data cable before removing the other board.
This board is powered by a Renesas R5F2133 16-bit microcontroller.
No flash photography, please, but this PCB does host the two IR blasters, with one conveniently on the side for the QWERTY keyboard.
Peeling back the remote's keypad is as easy as peeling a banana. Underneath is the capacitive touch trackpad.
A lot of strong adhesive is used to hold this board in place.
If this comes loose, your movie night will be gone with the wind, hence the generous amount of adhesive.
Excess adhesive usually doesn't get in our way. With a little bit of patience, our iFixit guitar picks, and a spudger, we free the trackpad from the frame.
The trackpad is controlled by the popular Synaptics T1021A Touch Controller, also used in the Logitech Revue.
Which reminds us, it's time to revue the Vizio Co-Star's repairability.
Vizio Co-Star Repairability: 8 out of 10 (10 is easiest to repair)
The outer case only requires a little bit of prying with a plastic opening tool to open.
The only screws used in the Co-Star are standard Phillips #0.
Most of the components are easily accessible and thus easily replaced in case of failure.
Removing the remote's QWERTY keypad is painless, making regular cleaning a relatively simple task.
An abundance of glue securing the trackpad to the front of the remote makes removal difficult.
2条评论
I have an inquiry not so much related to fixing procedures but to functionality. The important question for me is, if it is compatible with Apple Mountain Lion-based computer equipment? I had a Western Digital WDTV Live Plus I recently sold on auction because Apple mucked around with the network layer stack, or some unfamiliar jargon like that as explain a while back by WD support staff. Other then that, if the Vizio Co-Star does functionally work similar to an Apple TV, but provides greater connectivity in home network with Apple computers and more versatility in video codec playback I may want to get one of these.
Thanks for the guide teardown. You folks do a terrific job at ifixit.
