拆解
这个拆解是不是维修指南。 要维修你的的Toy,请使用我们的维修手册。
This is how the toy truck look before starting the takedown process
Using a big phillips screwdriver unscrew the housing that holds the wheels
Use a small phillips screw driver to unscrew the circuit board
Detach all the parts, including the wheels and truck top.
Once you detach the car top you remove the case that is covering the base of the car
Use wire snips to cut the batteries from the circuit board
与2其他贡献者
于10/19/16注册
119 声望
撰写一个指南
徽章: 0
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 1,352
