跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的Samsung Galaxy Buds Pro,请使用我们的维修手册
    最后的想法
    • The charging case is very easy to disassemble. Its battery is modular and easy to access and replace.
    • Some force is required to open the Buds, which can lead to some slight cosmetic damage and is a daunting first step for a repair.
    • The Buds are only semi-modular: their main circuit boards are easily accessible and held down with Phillips screws, but their batteries use soldered connections.
    • The Buds' drivers are practically inaccessible, making their eventual replacement tedious at best, but most likely downright destructive.
    可修复性评分
    3
    可修复性10分中得3分
    (10是最容易修复)
Taylor Dixon
于06/26/18注册
67,119 声望
创作了94篇指南
10条评论
Samsung making less repairable earbuds: “It’s evolving, just backwards.”
Ethan Zuo - 回复
Is dropped one ear bud few times and touch control stopped working one it ..except that everything works fine even the volume control…how to fix it?
Jakub Serafin - 回复
I love how easy the case is to take apart, however I cannot seem to locate a replacement battery for the charging case. Any idea where I could locate one?
Trevor Reed - 回复
Looks like the Galaxy Watch 46mm battery!
https://www.reichelt.com/de/en/battery-f...
I haven't tried it tho, but will have to soon because my Buds Pro case got water damaged. Thankfully it charges the buds but not the case, so I'll try to replace the battery and see if that helps.
Oscar de León -
Found the one! After disassembling my case I could check the actual part number
https://www.ebay.com/itm/354134695747?ha...
Oscar de León -
Is it possible to buy just the battery for the SM-R190 case?
I left my case and buds in washing machine. The ear buds have dried out and seem to work fine now. I had to open the case and dry it out and clean contacts. The case and buds charge to 100%, but when I disconnect USB charger, the case charge quicky drops to zero (in minutes). I am hoping it is just the battery that needs replacing. The buds will charge in the case.
Glenn Lindsay - 回复
Hi,
I have copied link posted by Oscar de Léon and ordered the battery. He has had EXACTLY the same problem as me.
Thanks, I hope that solves my problem, i.e. it is not something else.
Glenn Lindsay - 回复
Struggling to replace the magnet after dropping and the case opened.
I can still charge the case/buds but the case doesn’t snap shut anymore and stays slightly open so the case discharges quickly but the buds stay good. 🙏
Andrew McKelvey - 回复
where to find the charging connector
ayub shaikh - 回复
Does anyone else have tuis issue? I have intermittent right bud charging issues. It appears that the connection is not being made. I found if I turn the charging case upside down, and tap it it will disconnect from my phone and is starts charging. But bump it later and it connects to phone and stops charging.
David Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 156
过去 30 天: 544
总计 24,843
