跳转到主内容
你所需要的
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的Samsung Galaxy Buds Pro,应参考我们的维修指南
    最后的想法
    • The charging case is very easy to disassemble. Its battery is modular and easy to access and replace.
    • Some force is required to open the Buds, which can lead to some slight cosmetic damage and is a daunting first step for a repair.
    • The Buds are only semi-modular: their main circuit boards are easily accessible and held down with Phillips screws, but their batteries use soldered connections.
    • The Buds' drivers are practically inaccessible, making their eventual replacement tedious at best, but most likely downright destructive.
    可修复性评分
    3
    可修复性10分中得3分
    (10是最容易修复)
Taylor Dixon
于06/26/18注册
70,491 声望
创作了94篇指南
10指南评论
Samsung making less repairable earbuds: “It’s evolving, just backwards.”
Ethan - 回复
Is dropped one ear bud few times and touch control stopped working one it ..except that everything works fine even the volume control…how to fix it?
Jakub Serafin - 回复
I love how easy the case is to take apart, however I cannot seem to locate a replacement battery for the charging case. Any idea where I could locate one?
Trevor Reed - 回复
Looks like the Galaxy Watch 46mm battery!
https://www.reichelt.com/de/en/battery-f...
I haven't tried it tho, but will have to soon because my Buds Pro case got water damaged. Thankfully it charges the buds but not the case, so I'll try to replace the battery and see if that helps.
Oscar de León -
Found the one! After disassembling my case I could check the actual part number
https://www.ebay.com/itm/354134695747?ha...
Oscar de León -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 59
过去 30 天: 262
总计 30,728
