跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Toy,请使用我们的维修手册
  1. Robie the Banker Teardown, Robie the Banker Teardown: 步骤 1 中的图像 1,2 Robie the Banker Teardown, Robie the Banker Teardown: 步骤 1 中的图像 2,2
    • It may look slightly creepy, but Robie taught me about money at a very young age, and incentivized me to save my spare change.
    • Sold in the US by Radio Shack in the 80s and 90s, this gift from my Grandma was a huge hit at our family's Christmas gathering.
    • But enough reminiscing! Let's tear this thing down to see what makes Robie tick.
  2. Robie the Banker Teardown: 步骤 2 中的图像 1,3 Robie the Banker Teardown: 步骤 2 中的图像 2,3 Robie the Banker Teardown: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Using our handy-dandy Spudger, we perform a craniotomy on Robie by carefully prying off the top plastic cover in order to get at the screws underneath.
  3. Robie the Banker Teardown: 步骤 3 中的图像 1,3 Robie the Banker Teardown: 步骤 3 中的图像 2,3 Robie the Banker Teardown: 步骤 3 中的图像 3,3
    • Lucky for us, Robie is held together with standard Phillips #2 screws throughout, and there are three of them holding his head cover in place.
  4. Robie the Banker Teardown: 步骤 4 中的图像 1,1
    • Well, this is terrifying. Quick! Let's move on to the next step before we get nightmares!
  5. Robie the Banker Teardown: 步骤 5 中的图像 1,3 Robie the Banker Teardown: 步骤 5 中的图像 2,3 Robie the Banker Teardown: 步骤 5 中的图像 3,3
    • Robie's eyes are loosely held in place, so let's remove them before they fall out accidentally and roll under the desk.
  6. Robie the Banker Teardown: 步骤 6 中的图像 1,3 Robie the Banker Teardown: 步骤 6 中的图像 2,3 Robie the Banker Teardown: 步骤 6 中的图像 3,3
    • Just two screws hold Robie's head to its body. After removing those, we can carefully lift the head up and set it off to the side.
    • These two screws are still accessible without removing Robie's head cover and eyes. So you can detach the entire head assembly in one piece if you need to get inside more quickly.
  7. Robie the Banker Teardown: 步骤 7 中的图像 1,2 Robie the Banker Teardown: 步骤 7 中的图像 2,2
    • Before we can go any further, we need to remove Robie's feet covers so we have more room when removing his body.
    • The power switch is located in his left foot—nothing in his right.
  8. Robie the Banker Teardown: 步骤 8 中的图像 1,2 Robie the Banker Teardown: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    $3.99
    购买
    • Robie's body is split into two halves, which are held in place by clips and tape.
    • Using some tweezers, removing the tape is a piece of cake.
  9. Robie the Banker Teardown: 步骤 9 中的图像 1,3 Robie the Banker Teardown: 步骤 9 中的图像 2,3 Robie the Banker Teardown: 步骤 9 中的图像 3,3
    • The clips are fairly weak (hence the tape, most likely), so separating the body enclosure is also a piece of cake.
  10. Robie the Banker Teardown: 步骤 10 中的图像 1,1
    • The motor assembly is attached to the base with three screws—two in the front and one in the back.
  11. Robie the Banker Teardown: 步骤 11 中的图像 1,3 Robie the Banker Teardown: 步骤 11 中的图像 2,3 Robie the Banker Teardown: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    Soldering Station Hakko FX888D-23BY
    $122.99
    购买
    • Unfortunately, the battery contacts are soldered to the motor assembly, so any repairs or replacement of the motor will require a soldering iron and some basic soldering skills to remove it entirely.
    • But once those two wires are removed, separating the motor assembly from the base is a cinch.
  12. Robie the Banker Teardown: 步骤 12 中的图像 1,2 Robie the Banker Teardown: 步骤 12 中的图像 2,2
    • The motor assembly is filled with all sorts of gears and servo motors that make Robie move.
    • If needed, you can open up the enclosure to gain access to these components by removing four screws, but we feel like this is a good stopping point for this teardown.
  13. Robie the Banker Teardown: 步骤 13 中的图像 1,1
    • Robie handled his teardown with aplomb! He'll be put back together so he can continue to eat coins in peace.
Craig Lloyd
于02/10/16注册
35,418 声望
创作了82篇指南
3条评论
I love to take things apart too. Sometimes I even fix things that are not broken…
Brett E. Chmura - 回复
Fun to see a relatively low-tech teardown. But I didn’t learn anything about how the innards actually make Robie move. Should I expect that from a teardown?
John Wackman - 回复
Thank you! Our Robie is broken and I would not have noticed the access in the back of the head. Hopefully we can fix it now that we have it open.
Marianne - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 35
过去 30 天: 121
总计 6,268
