跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Motorola Moto X Force,请使用我们的维修手册
  1. Motorola Moto X Force Teardown, Remove SIM card tray.: 步骤 1 中的图像 1,2 Motorola Moto X Force Teardown, Remove SIM card tray.: 步骤 1 中的图像 2,2
    • Remove it or it will be a barrier to remove motherboard.
  2. Motorola Moto X Force Teardown, Remove back cover.: 步骤 2 中的图像 1,3 Motorola Moto X Force Teardown, Remove back cover.: 步骤 2 中的图像 2,3 Motorola Moto X Force Teardown, Remove back cover.: 步骤 2 中的图像 3,3
    • Use heat gun to heat up back cover firstly.
    • Insert metal opening tool to open a gap and cut adhesives around.
    • Take care when sliding tool under the back cover, there are delicate antenna and other components that could be damaged by your glue slicing tool
  3. Motorola Moto X Force Teardown, Remove metal logo cover.: 步骤 3 中的图像 1,2 Motorola Moto X Force Teardown, Remove metal logo cover.: 步骤 3 中的图像 2,2
    • Use tweezers to cut adhesives underneath.
  4. Motorola Moto X Force Teardown, Remove middle frame.: 步骤 4 中的图像 1,3 Motorola Moto X Force Teardown, Remove middle frame.: 步骤 4 中的图像 2,3 Motorola Moto X Force Teardown, Remove middle frame.: 步骤 4 中的图像 3,3
    • Twist off 17 screws by T3 Torx screwdriver.
    • Take away rubber bracket securing NFC antenna and release NFC antenna connector.
  5. Motorola Moto X Force Teardown: 步骤 5 中的图像 1,3 Motorola Moto X Force Teardown: 步骤 5 中的图像 2,3 Motorola Moto X Force Teardown: 步骤 5 中的图像 3,3
    • Take away rubber bracket securing MIC flex and release microphone flex cable connector.
  6. Motorola Moto X Force Teardown, Remove side button.: 步骤 6 中的图像 1,1
    • After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
  7. Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: 步骤 7 中的图像 1,3 Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: 步骤 7 中的图像 2,3 Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: 步骤 7 中的图像 3,3
    • Release MIC connector.
    • There are adhesives existed underneath.
  8. Motorola Moto X Force Teardown, Remove headphone jack.: 步骤 8 中的图像 1,2 Motorola Moto X Force Teardown, Remove headphone jack.: 步骤 8 中的图像 2,2
    • Use tweezers to pry this part up.
  9. Motorola Moto X Force Teardown, Remove vibration motor.: 步骤 9 中的图像 1,2 Motorola Moto X Force Teardown, Remove vibration motor.: 步骤 9 中的图像 2,2
    • The vibrator is only fastened by the plastic bracket.
  10. Motorola Moto X Force Teardown, Remove NFC antenna along with  plastic board attached.: 步骤 10 中的图像 1,2 Motorola Moto X Force Teardown, Remove NFC antenna along with  plastic board attached.: 步骤 10 中的图像 2,2
    • There are a little bit adhesives around, but you can peel this part easily.
  11. Motorola Moto X Force Teardown, Remove loudspeaker.: 步骤 11 中的图像 1,2 Motorola Moto X Force Teardown, Remove loudspeaker.: 步骤 11 中的图像 2,2
    • Pry this part up.
  12. Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: 步骤 12 中的图像 1,3 Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: 步骤 12 中的图像 2,3 Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: 步骤 12 中的图像 3,3
    • Peel off the tape.
    • Twist off 2 screws.
    • Take care not to apply any lateral force to the motherboard to metal bracket electrical connector when removing the motherboard bracket. If abused, the tiny spring could break off at a later date and causing short circuits within the phone. The connector is to the right of the side button connector and above the copper film screened component.
  13. Motorola Moto X Force Teardown, Release battery connector and side button connector.: 步骤 13 中的图像 1,1
    • Release this two connectors carefully.
  14. Motorola Moto X Force Teardown, Release touch digitizer connector.: 步骤 14 中的图像 1,2 Motorola Moto X Force Teardown, Release touch digitizer connector.: 步骤 14 中的图像 2,2
    • The LCD assembly has two connectors, here is touchscreen connector.
  15. Motorola Moto X Force Teardown, ReleaseLCD display connector.: 步骤 15 中的图像 1,2 Motorola Moto X Force Teardown, ReleaseLCD display connector.: 步骤 15 中的图像 2,2
    • This one is display connector.
  16. Motorola Moto X Force Teardown, Release motherboard assembly.: 步骤 16 中的图像 1,3 Motorola Moto X Force Teardown, Release motherboard assembly.: 步骤 16 中的图像 2,3 Motorola Moto X Force Teardown, Release motherboard assembly.: 步骤 16 中的图像 3,3
    • Release signal cable connector.
    • Pry the motherboard assembly up.
  17. Motorola Moto X Force Teardown, Remove rear camera.: 步骤 17 中的图像 1,2 Motorola Moto X Force Teardown, Remove rear camera.: 步骤 17 中的图像 2,2
    • Moto X Force packs a 21-megapixel primary camera on the rear.
  18. Motorola Moto X Force Teardown, Release signal cable connector and remove it.: 步骤 18 中的图像 1,2 Motorola Moto X Force Teardown, Release signal cable connector and remove it.: 步骤 18 中的图像 2,2
    • Use tweezers to release the connector.
  19. Motorola Moto X Force Teardown, Remove proximity sensor flex.: 步骤 19 中的图像 1,2 Motorola Moto X Force Teardown, Remove proximity sensor flex.: 步骤 19 中的图像 2,2
    • With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
  20. Motorola Moto X Force Teardown, Pry up and remove battery.: 步骤 20 中的图像 1,2 Motorola Moto X Force Teardown, Pry up and remove battery.: 步骤 20 中的图像 2,2
    • Non-removable Li-Ion 3760 mAh battery.
  21. Motorola Moto X Force Teardown, Remove front-facing camera.: 步骤 21 中的图像 1,2 Motorola Moto X Force Teardown, Remove front-facing camera.: 步骤 21 中的图像 2,2
    • A 5-megapixel front shooter for selfies.
  22. Motorola Moto X Force Teardown, Remove earpiece.: 步骤 22 中的图像 1,2 Motorola Moto X Force Teardown, Remove earpiece.: 步骤 22 中的图像 2,2
    • Be careful to pry this part up, because it tends to fall apart easily.
  23. Motorola Moto X Force Teardown, Remove side button flex.: 步骤 23 中的图像 1,3 Motorola Moto X Force Teardown, Remove side button flex.: 步骤 23 中的图像 2,3 Motorola Moto X Force Teardown, Remove side button flex.: 步骤 23 中的图像 3,3
  24. Motorola Moto X Force Teardown: 步骤 24 中的图像 1,2 Motorola Moto X Force Teardown: 步骤 24 中的图像 2,2
    • Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
  25. Motorola Moto X Force Teardown: 步骤 25 中的图像 1,1
    • Done.
Witrigs
于11/24/15注册
69,493 声望
创作了378篇指南
9条评论
amoled
Danila Elchin - 回复
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Vikulov Aleksander - 回复
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
NCQ - 回复
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 25
总计 18,810
