跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的MacBook Pro 15" Unibody Mid 2010,请使用我们的维修手册
  1. MacBook Pro 15" Unibody Mid 2010 Teardown, MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 1 中的图像 1,1
    • Apple's need for faster and better processors has led it to incorporate Core i5s and i7s into its latest lineup of MacBook Pros.
    • Our new MacBook Pro's specifications:
    • 2.4 GHz Intel Core i5 with 3 MB shared level 3 cache
    • 4 GB of 1066 MHz DD3 SDRAM
    • 15.4 inch LED-backlit glossy widescreen display
    • Intel HD Graphics and NVIDIA GeForce GT 330M with 256 MB of GDD3 RAM
  2. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 2 中的图像 1,1
    • Apple is still using the model number A1286 for the new MacBook Pro. We'll have to find a new way to differentiate this laptop from previous models.
    • Perhaps Model A1286 Core i5? Only time will tell.
  3. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 3 中的图像 1,1
    • Removing the rear cover will get things going.
    • Servicing the battery is not super easy due to the fact that you need a Tri-point screwdriver to get it out of the machine.
  4. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 4 中的图像 1,1
    • Taking off the rear cover reveals a machine that is not very exciting or different from earlier MacBook Pro models.
    • As usual, there's a sticker warning against removing the battery. Por qué, Apple?
  5. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 5 中的图像 1,1
    • Silly sticker... You can't stop us!
    • For some odd reason, Apple has stopped using five-point Torx screws found on other MBP 15" Unibodies in favor of Tri-point screws. Try as you may, Apple, you won't win. We got all the screwdrivers right here.
    • The battery is now rated at 77.5 Wh. That's just a tad bit more than the 73 Wh battery found in last year's 15" model, but not enough to explain the 1-2 hour battery life improvement Apple is claiming for this machine.
    • Perhaps they optimized the Pro's power consumption?
  6. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 6 中的图像 1,1
    • The Wi-Fi/Bluetooth board location is one of the few major changes made to the new model.
    • Its layout closely resembles that of the MacBook Unibody.
  7. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 7 中的图像 1,3 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 7 中的图像 2,3 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 7 中的图像 3,3
    • Removing the AirPort/Bluetooth assembly first requires disconnecting the three antenna connectors with a plastic spudger.
    • A single screw is all that's left holding the assembly in place.
    • Two more screws need to be removed to separate the AirPort Express card.
  8. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 8 中的图像 1,1
  9. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 9 中的图像 1,1
    • The connectors as viewed, from left to right:
    • Wi-Fi/Bluetooth antenna
    • Camera cable
    • Optical drive
    • Speaker wires
    • Hard drive
    • Due to the redesign of the AirPort/Bluetooth interface, its connections are no longer integrated into the camera cable, greatly decreasing the size of the connector.
  10. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 10 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 10 中的图像 2,2
    • With the antenna out of the way, the optical drive can be removed.
    • The new MacBook Pro uses the same Seagate hard drive from the previous model.
  11. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 11 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 11 中的图像 2,2
    • Removing the speaker and subwoofer assembly requires removing four measly screws holding it on the upper case.
    • Apple changed the design of this speaker assembly slightly, moving from a single plastic enclosure to separate plastic enclosures for the speaker & subwoofer that are connected by the speaker leads.
  12. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 12 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 12 中的图像 2,2
    • Since the AirPort/Bluetooth board is mounted inside the all-metal case of this machine, Apple added an antenna that is mounted on the frame for the optical drive opening. Pretty clever!
    • This antenna is not found on the MacBook Unibody, probably because the case of that machine is plastic and blocks less RF transmission & reception.
  13. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 13 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 13 中的图像 2,2
    • After removing the two cooling fans and disconnecting many connectors, the logic board and DC-In board can be removed as one piece.
  14. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 14 中的图像 1,1
    • The logic board and heat sink assembly by itself.
    • The speaker, microphone, and port layout are unchanged from previous MBP 15" Unibody machines.
  15. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 15 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 15 中的图像 2,2
    • Intel Core i5 processor with integrated graphics.
    • NVIDIA GeForce GT 330M. The OS switches to the NVIDIA graphics for higher demand applications.
    • Intel BD82HM55 S LGZS Platform Controller Hub. Interestingly enough, the hub is not connected to the heat sink. Apparently, enough heat is convected from the surface of the silicon to remove the small amount of heat generated by the graphics switching operations.
  16. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 16 中的图像 1,1
  17. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 17 中的图像 1,1
    • The heat sinks can be separated from the logic board, leaving it very cold and lonely.
  18. MacBook Pro 15" Unibody Mid 2010 Teardown: 步骤 18 中的图像 1,1
    • The Core i5 was no match for iFixit.
    • Here are the remains of this lovely machine...
一条评论
Hi Walter,
I’m working to try to repair a MacBook Pro A1286 - it won’t start up. The owner said his 7-yr old dropped it, and it’s been sitting for some time. A visual inspection reveals no obvious damage externally, or internally, as a matter of fact, the MBP appears to be in pristine condition. There are no lights from the Magsafe power adapter port. I’ve tested the Magsafe adapter on another MacBook Pro, and it works. Any idea what other test I might try? Thank you in advance for your reply.
Bryan Nunez - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 165
总计 464,476
