简介
Use this guide to replace the entire display assembly.
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Use the tip of a spudger to rotate the plastic retainer away from the camera cable connector.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
41等其他人完成本指南。
