跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Mac mini Late 2012,请使用我们的维修手册
  1. Mac mini Late 2012 Teardown, Mac mini Late 2012 Teardown: 步骤 1 中的图像 1,1
    • Good things come in mini packages. This mini is packing:
    • 2.5 GHz dual-core Intel Core i5 or 2.3 GHz quad-core Intel Core i7
    • 500 GB hard drive or 1 TB hard drive configurable to a 1 TB Fusion Drive or 256 GB solid-state drive—upgradable with an extra hard drive or SSD using our dual hard drive kit
    • 4 GB, 8 GB, or 16 GB of DDR3 SDRAM
    • Intel HD Graphics 4000
    • Thunderbolt and HDMI ports
    • SDXC card slot
    • This mini lacks an optical drive, just like its predecessor.
  2. Mac mini Late 2012 Teardown: 步骤 2 中的图像 1,2 Mac mini Late 2012 Teardown: 步骤 2 中的图像 2,2
    • It's beginning to feel like Groundhog Day. The same model number (A1347) has graced the 2011 and 2010 minis.
    • The port layout is consistent with last year's model:
    • 10/100/1000BASE-T Ethernet
    • FireWire 800
    • HDMI (HDMI to DVI adapter included)
    • Thunderbolt (supports high-speed I/O and Mini DisplayPort)
    • Four USB 3.0 ports (an upgrade from last year's 2.0)
    • SDXC card reader
  3. Mac mini Late 2012 Teardown: 步骤 3 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 3 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 3 中的图像 3,3
    • Twist and shout!
    • A simple twist of the bottom cover and we're in. That is plus one for repairability.
    • Upgradeable RAM!! Oh, how we've missed you!
    • The 2012 iteration of the Mac mini is equipped with PC3-12800 DDR3 RAM.
    • It's refreshing to see an Apple product with user replaceable/upgradeable RAM.
  4. Mac mini Late 2012 Teardown: 步骤 4 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 4 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 4 中的图像 3,3
    • We're fans of easily removable fans.
    • Easily accessible fans mean soot sprites better run for cover, because cleaning dirty fans is no problem.
    • Need to clean your fan? Directions can be found here.
  5. Mac mini Late 2012 Teardown: 步骤 5 中的图像 1,2 Mac mini Late 2012 Teardown: 步骤 5 中的图像 2,2
    • We remove the fan cowling, eager to get at the Wi-Fi antenna plate.
    • We are really starting to suspect that Dr. Emmett Brown had something to do with this mini as the antenna board and grille look identical to the last two renditions.
    • Here we find the legendary Mac mini logic board removal tool in its natural habitat.
    • Note the ease of use as the tool swoops in to release the logic board of the mini.
  6. Mac mini Late 2012 Teardown: 步骤 7 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 7 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 7 中的图像 3,3
    • The first component off the logic board assembly is the speaker assembly.
    • The speaker cable was arranged in a twisted pair, probably to reduce EMI that could distort the sweet, iconic tones of the Apple startup sound.
  7. Mac mini Late 2012 Teardown: 步骤 8 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 8 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 8 中的图像 3,3
    • The Wi-Fi board, labeled BCM94331PCIEBT3B, stands no chance against our spudger as we make it truly wireless.
    • Removing the EMI shields allows us to peek at the ICs on the communications board:
    • Broadcom BCM4331 802.11 a/b/g/n Wi-Fi chip
    • Broadcom BCM20702 Bluetooth 4.0 transmitter
    • SiGe 5503A 2304A Dual Band 802.11a/b/g/n Wireless LAN Front End
    • SiGe 2598L
    • P2303A TUB2P
    • 7871 1228 C6050
  8. Mac mini Late 2012 Teardown: 步骤 9 中的图像 1,2 Mac mini Late 2012 Teardown: 步骤 9 中的图像 2,2
    • The heat sink is next to go.
    • Apple has really keyed in on their boomerang-style heat sink abilities—and for that, we applaud them. We know boomerangs can be tough to master.
    • Similar, again! We have not tried installing old 2011 mini parts in the 2012 mini, but we are certainly not ruling out the possibility!
  9. Mac mini Late 2012 Teardown: 步骤 10 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 10 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 10 中的图像 3,3
    • A series of screws and tightly wrapped antenna cables secure the rear I/O panel shield to the logic board.
    • A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield.
  10. Mac mini Late 2012 Teardown: 步骤 11 中的图像 1,1
    • Some mini players on the top of the not-so-mini logic board:
    • Cirrus Logic 4206B Audio Controller
    • SMSC USB2512B USB Hub Controller
    • Broadcom BCM57765 gigabit ethernet and memory card controller
    • Intel L232TB45 Thunderbolt Port Controller
    • LSI L-FW643E-2
    • DELTA 8904C-F Filter
  11. Mac mini Late 2012 Teardown: 步骤 12 中的图像 1,1
    • The rear side of the logic board:
    • Intel HM77 (SLJ8C) platform controller hub
    • Intel V227C254 2.5 GHz dual-core i5
    • SMSC 1428-7 system management bus temperature sensor
    • Parade PS8401A HDMI/DVI level shifter
    • LM4FS1AH
  12. Mac mini Late 2012 Teardown: 步骤 13 中的图像 1,2 Mac mini Late 2012 Teardown: 步骤 13 中的图像 2,2
    • Tucked away neatly near the rear of the mini is the hard drive.
    • Our model came with a 500 GB Hitachi hard drive.
    • The mini is one of the Macs launched with the Fusion Drive.
    • Apple's Fusion Drive is not to be confused with the Impulse Fusion Drive of Star Trek.
  13. Mac mini Late 2012 Teardown: 步骤 14 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 14 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 14 中的图像 3,3
    • Next up, we displace the power of the mini.
    • It is beginning to feel repetitive to say how repetitive Apple is in the design of the mini; nonetheless, the power supply appears identical to last year's model.
    • In this case, we have to say that repetition is a good thing, as the mini continues to be one of the most repairable devices that Apple produces.
    • Just like last year, the power supply provides 85 watts to the Mac mini—that's the same kind of electric juice as the AC adapter for a 15" or 17" MacBook Pro.
  14. Mac mini Late 2012 Teardown: 步骤 15 中的图像 1,3 Mac mini Late 2012 Teardown: 步骤 15 中的图像 2,3 Mac mini Late 2012 Teardown: 步骤 15 中的图像 3,3
    • We were especially curious to see if this new Mac mini is still compatible with our dual hard drive upgrade kit, so we got to testing it!
    • Following along with our own guide for the 2011 model was a snap, and everything fit perfectly.
    • After a quick reassembly, we booted this guy up for the first time—with 50% extra storage. Success!
  15. Mac mini Late 2012 Teardown: 步骤 16 中的图像 1,2 Mac mini Late 2012 Teardown: 步骤 16 中的图像 2,2
    • Mac mini Mid 2012 Repairability: 8 out of 10 (10 is easiest to repair).
    • No proprietary screws are found within the device.
    • You can easily upgrade your RAM and hard drive, as well as add a secondary drive.
    • There's no glue anywhere inside that needs to be removed while disassembling the mini.
    • The CPU is soldered to the logic board and not user-upgradeable.
    • While not difficult to do, you still have to remove almost all the internals in order to replace the power supply.
15条评论
Hello,
I see that Mac mini Late 2012 have a Hitachi HTS545050A7E362 HDD
What kind of SATA connection have that Hitachi HDD?
And what kind of SATA connection have Mac mini Late 2012? SATA II or SATA III?
Regards
nickeditor - 回复
Can you add in an SSD with your dual drive kit to see if Fusion turns on somehow?
Below - 回复
Can you confirm that you can add a second hard drive if you choose the fusion drive option? I believe Apple have used that extra space in the mac mini to pack in the 128GB SSD for the fusion drive.
Roy - 回复
when reinstalling the heatsink did you notice the heatsink does not 100% connect to the platform hub?
even when screwed down tight and new thermal paste applied there is still a paper thin gap between heatsink and platform controller hub
can anyone else confirm this???
thanks
kevin
beanieboy182@hotmail.com
kevin - 回复
I noticed this too
Victor -
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 170
过去 30 天: 900
总计 394,325
