你所需要的
Lift the flap to put it in the unlocked position, the panel should separate from the box without forcing.
Then to remove the hard drives, pull them towards you with a bit of force.
On the power supply there is a button, press it to move the power supply to the left (see picture)
Then pull the graphics card towards you to take it out of the box
With a screwdriver unscrew the two screws that hold the fan bracket to the board
Pull the fan towards you
Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
