跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Galaxy S23,请使用我们的维修手册
  1. Galaxy S23 Teardown, Remove the rear glass: 步骤 1 中的图像 1,2 Galaxy S23 Teardown, Remove the rear glass: 步骤 1 中的图像 2,2
    • First we heat the rear glass of the phone to melt all the adhesive that glues the glass to the rest of the phone. We can do it either with an iOpener or with a heat gun.
    • Now with a flat object or with an opening pick we cut the remaining adhesive by inserting it between the glass and the rest of the phone and passing it along the entire edge.
    • Now we can raise the back panel and we're done.
  2. Galaxy S23 Teardown, Remove the Wireless Coil and NFC Antenna: 步骤 2 中的图像 1,1
    • Unscrew the 6 Phillips #00 screws that weld the wireless charging base and the NFC antenna.
    • Disconnect the connector connecting the two antennas and remove everything.
  3. Galaxy S23 Teardown, Disconnect the Battery: 步骤 3 中的图像 1,1
    • Unplug the connector to disconnect the battery.
  4. Galaxy S23 Teardown, Unscrew the Charging Board: 步骤 4 中的图像 1,1
    • Remove the 7 #00 Phillips screws that secure the charging board to the rest of the phone.
  5. Galaxy S23 Teardown, Remove the SIM: 步骤 5 中的图像 1,1
    • Use a fine tool to pull out the SIM tray.
  6. Galaxy S23 Teardown, Remove the connectors: 步骤 6 中的图像 1,1
    • Remove the connector with your fingers or a flat tool.
  7. Galaxy S23 Teardown, Remove the Front Camera Protector: 步骤 7 中的图像 1,1
    • Unscrew the 5 Phillips #00 screws that secure the front camera protector to the rest of the phone.
  8. Galaxy S23 Teardown, Remove the Front Camera: 步骤 8 中的图像 1,1
    • Unplug the front camera connector and remove it.
  9. Galaxy S23 Teardown, Remove the Rear Cameras: 步骤 9 中的图像 1,2 Galaxy S23 Teardown, Remove the Rear Cameras: 步骤 9 中的图像 2,2
    • Remove the two Phillips #00 screws that secure the rear camera protector to the rest of the phone.
    • Unplug the three connectors of the three rear cameras and remove them.
  10. Galaxy S23 Teardown, Remove the Charging Board: 步骤 10 中的图像 1,1
    • Unscrew the three Phillips #00 screws that secure the docking board to the rest of the phone and then remove it.
  11. Galaxy S23 Teardown, Remove the battery: 步骤 11 中的图像 1,3 Galaxy S23 Teardown, Remove the battery: 步骤 11 中的图像 2,3 Galaxy S23 Teardown, Remove the battery: 步骤 11 中的图像 3,3
    • With the special tab, detach it and pull to facilitate the removal of the battery.
  12. Galaxy S23 Teardown, Remove add-ons: 步骤 12 中的图像 1,2 Galaxy S23 Teardown, Remove add-ons: 步骤 12 中的图像 2,2
    • Remove the volume keys motherboard and them too.
  13. Galaxy S23 Teardown, Finished: 步骤 13 中的图像 1,1
    • We have completely disassembled the new Samsung Galaxy S23.
Andrea Alfani
于04/20/22注册
7,697 声望
创作了5篇指南
团队
Kid fixers Kid fixers 的会员
Community
162 名成员
创作了300篇指南
8条评论
You beat iFixit to the punch! Nice work. They're really falling behind. Good thing we have awesome users like yourself! Thank you!
Damien Lobb - 回复
Thank You so much i really appreciate it thank you so much i really appreciate it
Andrea Alfani -
Will the microphone get damage if I wrongly insert the sim pin into it?
apple terr - 回复
Mine did not damaged, all works properly)
Ramil Salakhetdinov -
添加评论
浏览统计数据:
过去 24 小时: 53
过去 7 天: 408
过去 30 天: 1,653
总计 28,725
