跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Dell Latitude D620,应参考我们的维修指南
  1. Dell Latitude D620 Teardown, Removing Keyboard Bezel: 步骤 1 中的图像 1,2 Dell Latitude D620 Teardown, Removing Keyboard Bezel: 步骤 1 中的图像 2,2
    • Open the laptop's screen 180 Degrees so it is straight back.
    • Use a flat head screwdriver or a spudger to pry the top bezel off. Work it side to side until the bezel is freed from the chassis, exposing 3 screws
  2. Dell Latitude D620 Teardown, Removing Keyboard Screws: 步骤 2 中的图像 1,1
    • Remove the 3 Phillips screws securing the keyboard.
    • Just remember to keep your screws organized! It will make everything much easier.
  3. Dell Latitude D620 Teardown, Removing the Keyboard: 步骤 3 中的图像 1,2 Dell Latitude D620 Teardown, Removing the Keyboard: 步骤 3 中的图像 2,2
    • Use your fingers to carefully lift up the keyboard. Refer to the first picture for guidance.
    • Carefully pull the keyboard upwards toward the LCD screen so it can be released from the bottom tabs.
    • Carefully lift the keyboard so the keys are resting on the palmrest, this will expose the ribbons for the keyboard, trackpad and Tracking Nub.
  4. Dell Latitude D620 Teardown, Removing Ribbons: 步骤 4 中的图像 1,2 Dell Latitude D620 Teardown, Removing Ribbons: 步骤 4 中的图像 2,2
    • First insert a small flat head screwdriver or a spudger into the small notch in between holding down the ribbon.
    • Then grab the metal bar on top of the keyboard connector and pull straight up. The cable should come free.
  5. Dell Latitude D620 Teardown, Display Connector: 步骤 5 中的图像 1,2 Dell Latitude D620 Teardown, Display Connector: 步骤 5 中的图像 2,2
    • Grab the top of the display connector and pull it straight up and out.
    • This connector requires a little more force than the others, so it may take some effort.
  6. Dell Latitude D620 Teardown, WLAN Card Antenna Removal: 步骤 6 中的图像 1,3 Dell Latitude D620 Teardown, WLAN Card Antenna Removal: 步骤 6 中的图像 2,3 Dell Latitude D620 Teardown, WLAN Card Antenna Removal: 步骤 6 中的图像 3,3
    • Use a tool or your fingers to gently remove the antenna cables from the wireless card.
  7. Dell Latitude D620 Teardown, WLAN Card Removal: 步骤 7 中的图像 1,3 Dell Latitude D620 Teardown, WLAN Card Removal: 步骤 7 中的图像 2,3 Dell Latitude D620 Teardown, WLAN Card Removal: 步骤 7 中的图像 3,3
    • Pull back the clips by the antenna connectors, and the card should rise up on its own. Gently remove the card from its socket.
  8. Dell Latitude D620 Teardown, WWAN Card Removal: 步骤 8 中的图像 1,3 Dell Latitude D620 Teardown, WWAN Card Removal: 步骤 8 中的图像 2,3 Dell Latitude D620 Teardown, WWAN Card Removal: 步骤 8 中的图像 3,3
    • Not all devices have a WWAN Card, so most people can skip this step.
    • Using similar procedures as the WLAN, disconnect the single antenna cable, push the rear clips back and remove the card.
  9. Dell Latitude D620 Teardown, LCD Screws: 步骤 9 中的图像 1,2 Dell Latitude D620 Teardown, LCD Screws: 步骤 9 中的图像 2,2
    • Close the laptop screen completely, make sure it clips in place.
    • Follow the Green bullet first then move onto the Blue bullet.
    • Make sure no cables or parts get caught in the hinge.
    • The bottom screw is labeled with D, remove it.
    • The screw on the rear is not labeled, remove it as well.
    • Repeat this for the opposite side of the laptop.
  10. Dell Latitude D620 Teardown, LCD Screen Removal: 步骤 10 中的图像 1,2 Dell Latitude D620 Teardown, LCD Screen Removal: 步骤 10 中的图像 2,2
    • Very, VERY carefully open up the screen so it is at a 90° angle with the palmrest.
    • Pull it straight up, making sure all cables are free of their routing ares.
  11. Dell Latitude D620 Teardown, Remaining Screw Removal: 步骤 11 中的图像 1,3 Dell Latitude D620 Teardown, Remaining Screw Removal: 步骤 11 中的图像 2,3 Dell Latitude D620 Teardown, Remaining Screw Removal: 步骤 11 中的图像 3,3
    • Remove all of the remaining screws on the laptop with a Phillips screwdriver.
    • There are screws on the top under the keyboard as well, remove those.
    • All of the screws with a P by them means they secure the palmrest. This will help you keep organized.
  12. Dell Latitude D620 Teardown, Palmrest Removal: 步骤 12 中的图像 1,2 Dell Latitude D620 Teardown, Palmrest Removal: 步骤 12 中的图像 2,2
    • Seperate the palmrest from the device, starting from the back by sliding it forward and pulling it most of the way off.
    • Don't remove it completely, there is still one connector attached.
  13. Dell Latitude D620 Teardown, Trackpad Cable Removal: 步骤 13 中的图像 1,1
    • Pull the trackpad connector straight out of the motherboard.
    • Don't pull on it by the cables, grab as close to the socket as you can.
  14. Dell Latitude D620 Teardown, Heatsink Unscrewing: 步骤 14 中的图像 1,2 Dell Latitude D620 Teardown, Heatsink Unscrewing: 步骤 14 中的图像 2,2
    • With a Phillips screwdriver, remove the 4 screws on the heatsink, in order of the numbers of the metal.
    • Loosening the screws out of order can be damaging.
  15. Dell Latitude D620 Teardown, Heatsink Removal: 步骤 15 中的图像 1,3 Dell Latitude D620 Teardown, Heatsink Removal: 步骤 15 中的图像 2,3 Dell Latitude D620 Teardown, Heatsink Removal: 步骤 15 中的图像 3,3
    • Grab the heatsink and remove it, it may require force.
    • There is still thermal paste and a thermal pad attached.
  16. Dell Latitude D620 Teardown, Cleaning Thermal Paste: 步骤 16 中的图像 1,3 Dell Latitude D620 Teardown, Cleaning Thermal Paste: 步骤 16 中的图像 2,3 Dell Latitude D620 Teardown, Cleaning Thermal Paste: 步骤 16 中的图像 3,3
    • Clean the remaining thermal compound off of the CPU. Remove the thermal pad if it is still stuck to the GPU.
  17. Dell Latitude D620 Teardown: 步骤 17 中的图像 1,3 Dell Latitude D620 Teardown: 步骤 17 中的图像 2,3 Dell Latitude D620 Teardown: 步骤 17 中的图像 3,3
    • Several more photos of the Intel Core Duo.
  18. Dell Latitude D620 Teardown, Remove the CPU.: 步骤 18 中的图像 1,3 Dell Latitude D620 Teardown, Remove the CPU.: 步骤 18 中的图像 2,3 Dell Latitude D620 Teardown, Remove the CPU.: 步骤 18 中的图像 3,3
    • Gently turn the screw above the socket and lift the CPU out.
    • The End!
Nicholas Ouimet
于10/16/09注册
3,548 声望
创作了11篇指南
8条评论
Seems like it would make a perfect "Hackintosh."
Chris Green - 回复
来自 Chris Green 的话:
Yes. It does indeed. I've been using it as a hackintosh sense early February. I had Mac OSX 10.6.2 on it, even before I performed this tear down. I was able to use software updater to go strait from 10.6.0 to 10.6.2. Skipping 10.6.1. I've only had a few kernel panics. I've even been using the iPhone SDK. It is a very stable hackintosh. The GMA 950 can even play The SIms 3 w/o any issues.
Nicholas Ouimet - 回复
Fantastic guide!! Thank you for taking the time and effort to create it!
Steve Weinrich - 回复
There is a little flat, white, Multi-wire connector in the upper-left corner.
I suspect that this is where the optional Bluetooth module would be located, can anyone confirm this?
Thanks,
Tim D.
Tim downing - 回复
Yes, the flat white connector on the left side above the keyboard is for the optional bluetooth connector. It interfaces via USB.
souta95 -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 42
总计 69,461
