跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Apple USB Power Adapter,请使用我们的维修手册
  1. Apple USB Power Adapter Teardown, Separating the input panel: 步骤 1 中的图像 1,3 Apple USB Power Adapter Teardown, Separating the input panel: 步骤 1 中的图像 2,3 Apple USB Power Adapter Teardown, Separating the input panel: 步骤 1 中的图像 3,3
    • Use a hammer and a small chisel to carefully force the input panel open
    • Clamping the device helps prop the input panel open but, do not pull the panel away from the device forcefully, as there are small wires connected to the device components.
    • Be careful not to force the chisel into the device as you could damage internal components.
  2. Apple USB Power Adapter Teardown, Removing plastic casing: 步骤 2 中的图像 1,2 Apple USB Power Adapter Teardown, Removing plastic casing: 步骤 2 中的图像 2,2
    • Use dyke and pliers to cut outside casing to pry open the shell and remove the circuitry.
    • Recommend using hand saw to cut around the plastic.
    • Be careful not to cut forcefully as to prevent the internal components from getting damaged.
  3. Apple USB Power Adapter Teardown, Isolating internal components: 步骤 3 中的图像 1,3 Apple USB Power Adapter Teardown, Isolating internal components: 步骤 3 中的图像 2,3 Apple USB Power Adapter Teardown, Isolating internal components: 步骤 3 中的图像 3,3
    • Isolate the internal electrical components from the casing
    • Recommend unsoldering the wires from the input panel.
    • For help desoldering connections, follow this useful guide on 如何焊接和拆焊.
    • Use caution when soldering. The heated tip may cause damage to the board, the components, or burn you.
  4. Apple USB Power Adapter Teardown, Accessing individual components: 步骤 4 中的图像 1,3 Apple USB Power Adapter Teardown, Accessing individual components: 步骤 4 中的图像 2,3 Apple USB Power Adapter Teardown, Accessing individual components: 步骤 4 中的图像 3,3
    • Unsolder components that connect to the bottom and top circuit boards.
    • Detach the top and bottom circuit boards from the plastic separator.
  5. Apple USB Power Adapter Teardown, Exploration: 步骤 5 中的图像 1,2 Apple USB Power Adapter Teardown, Exploration: 步骤 5 中的图像 2,2
    • Observe that once the circuit boards are separated individual components can be accessed.
Juan Gonzalez
于01/24/19注册
422 声望
创作了2篇指南
团队
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 的会员
CPSU-WHITE-W19S18G1
4 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 212
总计 16,268
