跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Apple Cinema HD Display 30" Teardown, Intro: 步骤 1 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Intro: 步骤 1 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Intro: 步骤 1 中的图像 3,3
    • Gather your tools (look in the teardown description).
    • You do not specifically need the "64 Bit Driver Kit" I linked, you just need a general screwdriver kit with Torx screwdrivers/bits specifically.
    • The ratchet in the pictures included is not necessary.
    • Lay the cinema display face down on a soft surface in order to not scratch or harm the LCD panel.
  2. Apple Cinema HD Display 30" Teardown, Stand removal pt. 1: 步骤 2 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Stand removal pt. 1: 步骤 2 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Stand removal pt. 1: 步骤 2 中的图像 3,3
    • Unscrew the two screws on the sides of the stand where the stand connects to the display.
    • A ratchet may be useful here but isn't necessary.
    • Image 3: Screws remain.
  3. Apple Cinema HD Display 30" Teardown, Stand removal pt. 2: 步骤 3 中的图像 1,2 Apple Cinema HD Display 30" Teardown, Stand removal pt. 2: 步骤 3 中的图像 2,2
    • Remove the four Torx screws where the stand attaches to the cinema display.
    • Remove the stand.
    If you just remove the stand, you don’t have to remove four Torx screws.
    Just remove two Hex screws.
    Pan - 回复
    Do you know the size to these four torx screws ?
    thank you :-)
    reesemuzik - 回复
  4. Apple Cinema HD Display 30" Teardown, Left side panel: 步骤 4 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Left side panel: 步骤 4 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Left side panel: 步骤 4 中的图像 3,3
    • Wedge a putty knife into the plastic side piece, without trying to pry the plastic off yet!
    • Either use the heat gun to heat the plastic piece for about 30 seconds, or use the hair dryer for up to a minute.
    • Carefully use the putty knife to work the plastic side piece off the cinema display. Re-heat the plastic piece again if it doesn't come off with ease.
  5. Apple Cinema HD Display 30" Teardown, Right side panel: 步骤 5 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Right side panel: 步骤 5 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Right side panel: 步骤 5 中的图像 3,3
    • Repeat the steps in Step 4.
    • Work carefully when prying this specific side panel off. Be sure to NOT insert the putty knife near the buttons when removing the side panel with buttons (you risk severing the button board cable underneath the plastic piece).
    Hello, buttons are the same with the 20”?
    Thierry Grosjean - 回复
    Yeah, should be the same deal. I haven’t personally torn apart a 20” display so take my words with a grain of salt though ;-)
    tr121 - 回复
  6. Apple Cinema HD Display 30" Teardown, Panel under right side panel: 步骤 6 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Panel under right side panel: 步骤 6 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Panel under right side panel: 步骤 6 中的图像 3,3
    • Remove the four Torx screws.
    • Use a pry tool to remove the secondary side panel.
  7. Apple Cinema HD Display 30" Teardown, Left secondary side panel: 步骤 7 中的图像 1,2 Apple Cinema HD Display 30" Teardown, Left secondary side panel: 步骤 7 中的图像 2,2
    • Repeat Step 6 for the left secondary side panel.
    • The screws should be the same length and in the same place as the right side panel.
  8. Apple Cinema HD Display 30" Teardown, Undo latches: 步骤 8 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Undo latches: 步骤 8 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Undo latches: 步骤 8 中的图像 3,3
    • Wedge the putty knife in between the metal pieces (arrow in image).
    • Move the metal piece circled green towards the display panel to disengage the clip.
    • Repeat for the identical clip on the opposite side of the display.
  9. Apple Cinema HD Display 30" Teardown, Enclosure removal pt. 1: 步骤 9 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt. 1: 步骤 9 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt. 1: 步骤 9 中的图像 3,3
    • First image: Separate the metal enclosure at the bottom. Use prying tools to undo the retaining clips if needed.
    • Second image: Thread the all-in-one cable out of the hole in the metal enclosure.
  10. Apple Cinema HD Display 30" Teardown, Enclosure removal pt.2: 步骤 10 中的图像 1,3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt.2: 步骤 10 中的图像 2,3 Apple Cinema HD Display 30" Teardown, Enclosure removal pt.2: 步骤 10 中的图像 3,3
    • Peel up the tape (shown in the red circle). Then peel up the remaining component off the enclosure.
    • Not shown: Bend the enclosure apart just enough to slip the display panel assembly out of the enclosure.
    • Tip: Use a friend and have them hold the two parts of the enclosure apart while you lift the display panel assembly out of the enclosure.
  11. Apple Cinema HD Display 30" Teardown, All-in-one cable & logic board removal: 步骤 11 中的图像 1,3 Apple Cinema HD Display 30" Teardown, All-in-one cable & logic board removal: 步骤 11 中的图像 2,3 Apple Cinema HD Display 30" Teardown, All-in-one cable & logic board removal: 步骤 11 中的图像 3,3
    • Remove 3 screws holding the all-in-one cable in place (shown in red circles).
    • Remove three more screws (shown in blue circles).
    • Remove 5 more screws holding the logic board intact (shown in yellow circles).
tr121
于12/13/18注册
931 声望
撰写一个指南
团队
Kid fixers Kid fixers 的会员
Community
158 名成员
创作了296篇指南
8条评论
Hey thanks for posting this up… is it possible for you to share the LG display panel part number? I want to see if I can find one online.
Julian Wong - 回复
This wasn’t my teardown - merely a translation so I don’t know… sorry!
tr121 -
No worries thanks anyway!
Jude Lian - 回复
Hi,did you manage to get the panel model number ? And if you did how much was it ?
Stephen paladini -
These use LG Philips LM201W01 monitors, same as the iMac G5 for people looking for the panel information. You can also replace the CCFLs with LEDs for better life and no buzzing.
Naoki's Retro Corner - 回复
Naoki, thanks for the model reference for the 30" (do you have one for the 23" panels?). If one was to do an LED conversion, what LED panels would you recommend that are compatible with the 23" & 30" Apple displays? What about display driver boards and connections? Are there any guides relating to this LED conversion?
Mason Fowlkes -
Gracias perfecto.
Harry Macias - 回复
Your effort is appreciated, but a question where you can get the LCD panel of the 23-inch A1062 display
francis - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 134
总计 5,952
