跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的ALCATEL 5015A Pixi 3 (5) 3G,应参考我们的维修指南
  1. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Remove the inside panel - screws: 步骤 1 中的图像 1,2 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Remove the inside panel - screws: 步骤 1 中的图像 2,2
    • Once you have the back removed and the battery set aside, you have 4 (long screws) at the corners, and 4 (smaller) screws in the middle. Set these aside in a safe place. (I used the back of the phone itself)
  2. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: 步骤 2 中的图像 1,3 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: 步骤 2 中的图像 2,3 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separating the rear frame.: 步骤 2 中的图像 3,3
    • Find a small crevice along the outside and carefully insert your spudger, small screw driver or guitar pick tool inside and slide it along the length of the side to seperate the front assembly from the rear.
    • Carefully work the opposite side as well, you will need to duplicate while being mindful of the circuit board.
  3. ALCATEL 5015A Pixi 3 (5) 3G Teardown: 步骤 3 中的图像 1,1
    • Take care not to damage the ribbon cable connectors (red arrows) coming from the front display assembly attempting to lift the circuit board from the display.
    • The guitar pick tool (orange arrows) should slide easily under the circuit board except for where the cables might still be connected.
  4. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Camera & Cables: 步骤 4 中的图像 1,2 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Camera & Cables: 步骤 4 中的图像 2,2
    • Carefully remove the rear facing camera (pink box) and lift the speaker upwards (blue box - do not try to disconnect). The speaker is held in place by the magnet on the backside. You may need flat edge under the side to separate it from the plate of metal.
    • Carefully seperate the ribbon attachment from the top (red box) to remove the front facing camera (adhered to the front) with a small piece of adhesion.
  5. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: 步骤 5 中的图像 1,2 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully lift (with tweezers or small pliers) the connection indicated by the yellow box(s)
    • Next lift, with tweezers or spudger (carefully) the connection indicated by the blue box marker.
    • You will need a flat surface to lift carefully the clip which holds the connector indicated by the green box. You can then use a pair of tweezers (or your fingernails?) to slide the connector to the side.
  6. ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: 步骤 6 中的图像 1,3 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: 步骤 6 中的图像 2,3 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Separate the circuit board: 步骤 6 中的图像 3,3
    • The circuit board should separate with little or no effort.
    • The orange box marker shows sighs of water damage. This phone had been dropped in a puddle.
Thomas Keats
于02/08/16注册
343 声望
撰写一个指南
团队
Rainbow Computers Rainbow Computers 的会员
Business
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 3,512
