跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的PlayStation,应参考我们的维修指南
  1. (TC) PlayStation Teardown, (TC) PlayStation Teardown: 步骤 1 中的图像 1,1
    • Flip the unit upside down to access the six screws on the bottom.
    • Remove the six screws indicated with a Phillips-head screwdriver. All the screws are of the same length.
  2. (TC) PlayStation Teardown: 步骤 2 中的图像 1,1
    • Turn the unit back over, and pull the top half up and away from the device.
  3. (TC) PlayStation Teardown: 步骤 3 中的图像 1,1
    • Unplug the laser assembly's power cable and ribbon cable from the main board.
    • Remove the two screws on the memory card/controller port, disconnect the ribbon cable, and lift it out of the case.
  4. (TC) PlayStation Teardown: 步骤 4 中的图像 1,2 (TC) PlayStation Teardown: 步骤 4 中的图像 2,2
    • To remove the power supply, disconnect the cable and remove the two screws, then lift it out of the case.
  5. (TC) PlayStation Teardown: 步骤 5 中的图像 1,2 (TC) PlayStation Teardown: 步骤 5 中的图像 2,2
    • Remove the 3 screws from the shield.
  6. (TC) PlayStation Teardown: 步骤 6 中的图像 1,2 (TC) PlayStation Teardown: 步骤 6 中的图像 2,2
    • Remove the 5 Phillips screws.
    • You can now lift the main board out of the case.
  7. (TC) PlayStation Teardown: 步骤 7 中的图像 1,2 (TC) PlayStation Teardown: 步骤 7 中的图像 2,2
    • Lift the RF shield out of the case.
  8. (TC) PlayStation Teardown: 步骤 8 中的图像 1,2 (TC) PlayStation Teardown: 步骤 8 中的图像 2,2
    • Reinstall the RF shield by dropping it in and lining up the slots and tabs.
  9. (TC) PlayStation Teardown: 步骤 9 中的图像 1,2 (TC) PlayStation Teardown: 步骤 9 中的图像 2,2
    • Replace the main board. Only install the screws indicated in red.
  10. (TC) PlayStation Teardown: 步骤 10 中的图像 1,1
    • Replace the top shield, and secure with the 3 screws indicated.
    • Reinstall the memory card / controller module. Connect the ribbon cable and replace the 2 screws.
  11. (TC) PlayStation Teardown: 步骤 11 中的图像 1,1
    • Align the optical drive assembly with the three pegs.
    • Reconnect the power and data cables for the optical drive.
  12. (TC) PlayStation Teardown: 步骤 12 中的图像 1,1
    • Slide the cover on the system in the same way you took it off and replace the black screws indicated.
  13. (TC) PlayStation Teardown: 步骤 13 中的图像 1,1
    • Plug in the console and turn it on.
    • Thanks for looking at my teardown!
Nick
于11/10/09注册
95,032 声望
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 106
总计 44,523
