我的问题
The color scheme on my old screen started disinigrating and needed to be replaced.
我的修理方法
The repair went okay. It took a bit longer than anticipated because I couldn't get the ribbon cable in the hinge properly. That took me about an hour alone. I also swapped 2 screws, oops. No big deal though as they were about the same size and worked in the holes I put them in.
我的建议
Double check that you have the screen faceplate on the correct way before trying to close it all up. It may cause frustration if you don't.
0条评论
