MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery
  • MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery / Fix Kit
  • MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery / Part Only
$89.99
$89.99
当产品有货时,我们将给你发送消息。
所有US$79.00及以上的订单免运费
浏览我们的商店
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
产品详细说明
功能
功能
This MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery Fix Kit is everything you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 5510 mAh—so you know you're getting the best part money can buy. This fix kit comes with a brand new battery and all the tools you need to make the fix.
Fix Kit Contents:
Note: Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
兼容性
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
显示 2 个更多的设备
维修的故事
用户头像
James May's Story Photo #1426220
我的问题
Battery life was getting so miserable, I couldn't depend on the old 'Pro anymore. I was seriously thinking it might be time to buy a new one, but I decided to try a new battery first.
我的修理方法
The iFixit kit came with everything I needed, and swapping the battery took only a few minutes. It was wonderfully re . . .
用户头像
borist72's Story Photo #1426210
我的问题
Due to an upcoming trip, I finally decided to upgrade the original battery in my mid-2010 MacBook Pro. I contemplated purchasing the replacement on Amazon, eBay, or directly from Apple, but decided to go with iFixit after using their other products for multiple Mac repairs over the past 10 years. . . .
用户头像
Scott Stuck's Story Photo #1367620
我的问题
As you can see from the photo, my old battery decided to hit puberty and started growing. To my surprise, the existing home we provided for that battery was too small. As a result, it decided to grow through the trackpad as quickly as possible.
我的修理方法
This was a super easy repair, albeit slightly scary be . . .
用户头像
我的问题
Original battery from 2010 was dead - not handy for a laptop :)
我的修理方法
Flawless
我的建议
Great tools to go with it - gets the job done well!
用户头像
我的问题
Battery life zero
我的修理方法
The driver bits did not fit screw heads well, if not careful could strip screw heads. Don’t be afraid to use excessive pressure
我的建议
Machine driver bits that fit screw heads better ie. find a better quality supplier maybe Germany
用户头像
我的问题
battery said it needed to be replaced and was not holding as charge for very long
我的修理方法
Perfect. Using the provided tool I complete the repair in about 10 minutes with any problems.
我的建议
I've been using ifixit repair guides for years and they are simple the best. Nice step by step instructions.
用户头像
我的问题
I still had the factory battery in my MacBook Pro. I bought it in 2009 so the battery was definitely at end of life. It would only stay charged for a half hour if it was off the charger.
我的修理方法
Great! Super easy. I did watch a Youtube video to make sure I was doing it correctly, but most could do the switch . . .
用户头像
我的问题
wanted more battery life
我的修理方法
Great - this is easy.
我的建议
The instructions a bunch of steps for removing the faceplate entirely. The video skips that. I started removing the faceplate then realized I didn't need to -- so go with the video version. Much faster!
Works like a charm
用户头像
我的问题
old battery
我的修理方法
great
我的建议
nope
用户头像
我的问题
To speed things up, It was nt too bad replacing the battery with help of iFixit instruction, clearly read and done in 30 min
Thanks
Ron Gabriel
我的修理方法
Not bad, took 30 min
我的建议
Didnt remove the screen cover, held the screen up and use rubber band wrapped around L stand
显示更多
