MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
  • MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
US$499.99
US$499.99
产品详细说明
描述
描述
This Late 2012 to Early 2013 MacBook Pro 13" Retina replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
零件包括
零件包括
  • 2560 x 1600 13.3" Retina LCD Screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
兼容性
兼容性
  • MacBook Pro 13" Retina A1425 Late 2012 to Early 2013
产品规格
产品规格
Part #:
661-7014
Resolution:
2560x1600
Diagonal Size:
13.3"
兼容性
MacBook Pro 13" Retina Display Early 2013
A1425 (EMC 2672) 2.6 GHz
A1425 (EMC 2672) 3.0 GHz
MacBook Pro 13" Retina Display Late 2012
A1425 (EMC 2557) 2.5 GHz
A1425 (EMC 2557) 2.9 GHz
维修的故事
用户头像
我的问题
Crack in display
我的修理方法
Very good, the only difficult part was to replace the new display and connect it with the first 2 screws.
我的建议
用户头像
我的问题
I carelessly put a small crack in my previous screen and after getting an estimate from a shifty guy at the Apple store I would have been better off replacing the whole Macbook. I'm in college and I need to save the money.
我的修理方法
The process was smooth and easy with excellent steps and pictures to help buls . . .
用户头像
我的问题
Cracked display.
我的修理方法
Smoothly.
我的建议
Must have proper screwdrivers (Torx 2, 5, 6, 7, and 8, I believe).
用户头像
我的问题
My old retina display was dying. I had a streak of dying pixels down the left side of my monitor
我的修理方法
The replacement was simple thanks to IFIXIT! Before even cracking open the case I knew which tools I needed, the task at hand, and the basic time I would need to allot for the job. I swapped out my lid as . . .
用户头像
我的问题
The screen was damaged when the laptop was dropped
我的修理方法
Screen replaced
我的建议
I had someone experienced in repairing my laptop complete the repair. Very satisfied and happy with the outcome.
用户头像
Phil Wymore's Story Photo #858008
我的问题
Cracked Retina display
我的修理方法
It couldn't have been easier -- in fact it was actually fun. The tools were perfectly matched for each task and the instructions were very easy to follow.
我的建议
Don't be intimidated
用户头像
jimpandolfo's Story Photo #901875
jimpandolfo's Story Photo #901873
jimpandolfo's Story Photo #901878
我的问题
Coating was coming off my retina screen.
我的修理方法
The web site instructions were spot on! The repair was easy and fun to do. I had 0 issues. Thanks!!!
我的建议
As long as you follow the directions, it's an easy repair. Took me less than 30 minutes
显示更多
