跳转到主内容
why! N131WU Laptop: Accessing the main components
你所需要的
  1. why! N131WU Laptop: Accessing the main components, Remove the Screws: 步骤 1 中的图像 1,1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Laptop: Accessing the main components, Remove the Keyboard: 步骤 2 中的图像 1,3 why! N131WU Laptop: Accessing the main components, Remove the Keyboard: 步骤 2 中的图像 2,3 why! N131WU Laptop: Accessing the main components, Remove the Keyboard: 步骤 2 中的图像 3,3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Laptop: Accessing the main components, Remove Keyboard Connections: 步骤 3 中的图像 1,3 why! N131WU Laptop: Accessing the main components, Remove Keyboard Connections: 步骤 3 中的图像 2,3 why! N131WU Laptop: Accessing the main components, Remove Keyboard Connections: 步骤 3 中的图像 3,3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Laptop: Accessing the main components, Remove the upper screws: 步骤 4 中的图像 1,2 why! N131WU Laptop: Accessing the main components, Remove the upper screws: 步骤 4 中的图像 2,2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
结论
To reassemble your laptop, follow the instructions in reverse.
6等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
31,100 声望
创作了264篇指南
9条评论
Valable aussi pour le portable CLEVO N141ZU
Thomas B - 回复
Merci nous avons ajouté les autres modèles compatibles
EkimiaMichel -
Bonjour MANIP pour sortir clavier, ce dernier ne vient pas ! ça tient par vis centrale VERTE impossible de le sortir sur CLEVO N141ZU précision toutes les vis sont sorties ( 10 rouges et 2 vertes ça retient vers intérieur a moins de tout casser ! ) a plus Merci Raymond Feix
Raymond Feix - 回复
Si les 2 vertes sont bien retirées , il n y a aucun risque à pousser
EkimiaMichel -
Bonjour, une fois toutes les vis retirées, il faut vraiment appuyer assez fortement pour déclipser le clavier sur un côté. Pour la suite du déclipsage, il faut reprendre délicatement depuis dessus en faisant le tour du clavier depuis la partie déclipsée.
Bonne chance!
Felice Suglia - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 1,442
