跳转到主内容
iView-776TPCII Battery Replacement
你所需要的
  1. iView-776TPCII Battery Replacement, Rear Panel: 步骤 1 中的图像 1,3 iView-776TPCII Battery Replacement, Rear Panel: 步骤 1 中的图像 2,3 iView-776TPCII Battery Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Battery Replacement: 步骤 2 中的图像 1,2 iView-776TPCII Battery Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
  3. iView-776TPCII Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
    • Do this all around the battery until it comes off.
    • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
    • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
  4. iView-776TPCII Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wires free from their connections.
    • To ease reassembly, take note of which wire went to the positive and negative terminals.
结论
3等其他人完成本指南。
Cory Gratzer
于09/16/15注册
586 声望
创作了5篇指南
团队
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G2
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 946
