跳转到主内容
iRulu AX760 Battery Replacement
你所需要的
  1. iRulu AX760 Battery Replacement, Battery: 步骤 1 中的图像 1,3 iRulu AX760 Battery Replacement, Battery: 步骤 1 中的图像 2,3 iRulu AX760 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Battery Replacement: 步骤 2 中的图像 1,1
    • Open your tablet.
  3. iRulu AX760 Battery Replacement: 步骤 3 中的图像 1,1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Battery Replacement: 步骤 4 中的图像 1,2 iRulu AX760 Battery Replacement: 步骤 4 中的图像 2,2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. 如何焊接和拆焊
  5. iRulu AX760 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove your old battery and replace it with the new battery.
结论
Perri
于03/20/18注册
171 声望
撰写一个指南
团队
IUPUI, Team S6-G4, Baechle Spring 2018 IUPUI, Team S6-G4, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S6G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 258
