简介
Use this guide to replace the Corner Brush Module on your iRobot Roomba S9+ (Model number: s955020). Be sure to be careful when you’re disconnecting wires. Only pull on solid plastic pieces and not wires. For more information, check out our troubleshooting page.
你所需要的
Place your Roomba upside down with the brush module facing you.
Push the grey tab by the top left corner of the brushes to release the retaining arm.
3等其他人完成本指南。
4指南评论
Wish there was a way to replace that plastic. Stripped on mine.
The brush spindle gets replaced as part of the motor assembly.
Now I just need to find a good part # for the motor assembly. I'm replacing mine because of the worn out plastic spindle too.
